[gdal-dev] Multithread deadlock
Even Rouault even.rouault at spatialys.com
Wed Sep 28 01:10:41 PDT 2016
Francisco,
> Bingo! I've just tested with an ENVI dataset and is failing, same issue
> with a few random blocks missing in the resulting rasters. Find below a
> link with the code for a simple test reproducing the issue (also included
> the ENVI dataset used). Just bear in mind that sometimes may generate the
> final raster properly, although, based on my testing, it is highly
> probable to get missing blocks with just a few runs:
> https://drive.google.com/open?id=0B-OCl1FjBi0YUkN4WWZmRjRfM1k
Please create a ticket about that in Trac.
> I'm not sure if it is related with the RawRasterBand, as my custom-driver
> does not inherit from that class. However, both drivers, ENVI and mine,
> inherit its custom raster band from GDALPamRasterBand. Oh .... now I see,
> RawRasterBand/RawDataset inherit from GDALPam corresponding objects ....
> Something weird its happening in the common part of these drivers...
I don't think this comes from GDALPam, but rather from the lower level
machinery of GDALRasterBand & GDALRasterBlock. As I said before, multi-
threaded writing has never properly worked and I'm not sure if the issue you
see is just an implementation bug or a design bug.
Even
http://www.spatialys.com
