[gdal-dev] SQL FID 0- or 1-based
Michael Sumner mdsumner at gmail.com
Fri Sep 30 23:23:09 PDT 2016
I forgot to add that I'm using 2.1.1, on Debian sid.
GDAL 2.1.1, released 2016/07/07
Cheers, Mike.
On Sat, 1 Oct 2016 at 16:20 Michael Sumner <mdsumner at gmail.com> wrote:
> Hello, I'm seeing that the OGRSQL virtual FID value is 0-based for
> shapefile, and 1-based for MapInfo (TAB or MIF).
> Is this driver-dependent generally, or is shapefile (or MI?) a special
> case?
> Using the autotest data I see
> ## no feature returned (there are 2)
> ogrinfo autotest/ogr/data/seamless_part1.tab -sql "SELECT * FROM
> seamless_part1 WHERE FID = 0"
> ## one feature returned
> seamless_part1 WHERE FID = 2"
> ## create analogous SHP
> ogr2ogr shp autotest/ogr/data/seamless_part1.tab seamless_part1
> ogrinfo shp -sql "SELECT * FROM seamless_part1 WHERE FID = 0"
> ogrinfo shp -sql "SELECT * FROM seamless_part1 WHERE FID = 2"
> Cheers, Mike.
> Dr. Michael Sumner
> Software and Database Engineer
> Australian Antarctic Division
> 203 Channel Highway
> Kingston Tasmania 7050 Australia
Dr. Michael Sumner
203 Channel Highway
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20161001/ea5dc910/attachment.html>
