[gdal-dev] GML lat-lon coverages and interoperability
Andrea Aime andrea.aime at geo-solutions.it
Mon Apr 3 05:58:01 PDT 2017
On Mon, Apr 3, 2017 at 2:32 PM, Rahkonen Jukka (MML) <
jukka.rahkonen at maanmittauslaitos.fi> wrote:
> With orthophoto coverages I believe that all cases could be handled with
> the default gridFunctions: startPoint at gml:Low, axisOrder +1 +2, sequence
> rule “Linear”. As far as I have understood GDAL trusts that this is also
> what the other partners do. However, it seems that GeoServer developers
> have decided to handle the latitude-longitude axis flip in WCS 2.0.1 by
> changing the order of grid axis with a function instead of writing the
> offsetVectors to suit with the default +1 +2 axis order.
> <gml:coverageFunction>
> <gml:GridFunction>
> <gml:sequenceRule axisOrder="+2 +1">Linear</gml:sequenceRule>
> <gml:startPoint>0 0</gml:startPoint>
> </gml:GridFunction>
> </gml:coverageFunction>
Hi Jukka,
the decision was not arbitrary, and imho, necessary.
Rasters pixels are normally represented as east/north, but OGC forces us to
describe geographic data in lat/lon order.
So how do you tell the client, "look, I'm telling you that the axis order
is north/east, but really, I'm giving you back data in east/north order
instead"?
Cheers
Andrea
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170403/924f3eb9/attachment.html>
