[gdal-dev] GML lat-lon coverages and interoperability
Rahkonen Jukka (MML) jukka.rahkonen at maanmittauslaitos.fi
Mon Apr 3 06:37:52 PDT 2017
Gdalinfo about my test image “4326.jp2”:
Size is 15518, 7355
Coordinate System is:
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0],
    UNIT["degree",0.0174532925199433],
    AUTHORITY["EPSG","4326"]]
Origin = (24.724834097819130,61.783882749023277)
Pixel Size = (0.000007567519986,-0.000007567519986)
Image Structure Metadata:
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left  (  24.7248341,  61.7838827) ( 24d43'29.40"E, 61d47' 1.98"N)
Lower Left  (  24.7248341,  61.7282236) ( 24d43'29.40"E, 61d43'41.61"N)
Upper Right (  24.8422669,  61.7838827) ( 24d50'32.16"E, 61d47' 1.98"N)
Lower Right (  24.8422669,  61.7282236) ( 24d50'32.16"E, 61d43'41.61"N)
-Jukka-
Lähettäjä: andrea.aime at gmail.com [mailto:andrea.aime at gmail.com] Puolesta Andrea Aime
Lähetetty: 3. huhtikuuta 2017 16:31
Vastaanottaja: Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi>
Kopio: 'gdal-dev at lists.osgeo.org' (gdal-dev at lists.osgeo.org) <gdal-dev at lists.osgeo.org>; geoserver-devel at lists.sourceforge.net
Aihe: Re: [gdal-dev] GML lat-lon coverages and interoperability
On Mon, Apr 3, 2017 at 3:19 PM, Rahkonen Jukka (MML) <jukka.rahkonen at maanmittauslaitos.fi<mailto:jukka.rahkonen at maanmittauslaitos.fi>> wrote:
    <gml:Envelope srsName="urn:ogc:def:crs:EPSG::4326">
      <gml:lowerCorner>61.7282236395245 24.7248340978191</gml:lowerCorner>
      <gml:upperCorner>61.7838827490233 24.8422668729657</gml:upperCorner>
Can you clarify which one is longitude and which one is latitude? :-)
It's one thing that really gets me about CITE tests too, if they wanted to make order obvious without further specs, the
coordinates of test data could have had some values greater than 90 ;-)
Cheers
Andrea
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility  for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170403/bf400b85/attachment-0001.html>
