[gdal-dev] ogr2ogr intersect very slow at command line with large	sqlite input
    CTL101
    chrislloyd2 at yahoo.co.uk
    Sun Apr  9 08:38:58 PDT 2017
Hi, I am attempting the following ogr2ogr sql intersect operation using gdal
2.1.3 at command line, and an input sqlite file that is 2.51GB in size. The
program has been running for a few days and seems to be processing, but is
very slow. The output file size is not incrementing as it does with small
test excerpts of the file. Has the program crashed? And how might I improve
performance? I have experimented with the -gt and --config cache options
somewhat.
ogr2ogr -gt 65536 -nlt PROMOTE_TO_MULTI25D --config OGR_SQLITE_CACHE 20480
-f SQLite -dsco SPATIALITE=YES output.sqlite input.sqlite -nln output
-dialect sqlite -sql "SELECT ST_Intersection(A.geometry, B.geometry) AS
geometry, A.name, B.name FROM inputtable1 A, inputtable2 B WHERE
ST_Intersects(A.geometry, B.geometry)"
Any advice appreciated. Regards, Chris
View this message in context: http://osgeo-org.1560.x6.nabble.com/ogr2ogr-intersect-very-slow-at-command-line-with-large-sqlite-input-tp5316545.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
