[gdal-dev] [Geoserver-devel] GML lat-lon coverages and interoperability
Andrea Aime andrea.aime at geo-solutions.it
Mon Apr 10 06:57:03 PDT 2017
Hi Even,
in CIS 1.1 they state:
Coverages are assumed to have a 1:1 correlation between the axis names
given in axis-Labels and gridLabels, i.e.: they shall relate pairwise,
given by their sequence position. For example, axisLabels=“Lat Long h date”
and gridLabels={i j k l} implies a correspondence of Lat with i, Long with
j, h with k, and date with l.
If there is no 1:1 correspondence between geographic and raster space axis,
then I see no other way but to use Function to explicitly correlate the two.
How would you propose to proceed instead?
Cheers
Andrea
On Mon, Apr 10, 2017 at 3:31 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On lundi 10 avril 2017 15:06:55 CEST Andrea Aime wrote:
> > Hi,
> > sorry I lost track of the subject. So, to close up, and approach where
> the
> > envelope is reported as "lat lon" and the "i j" raster space
> > axis would map pairwise, so i pointing north-wards and j east-wards,
> would
> > be considered valid?
> > E.g., if one rescaling says "i is going to be 200 pixels" it really means
> > the output image will be 200 pixels tall?
> IMHO, importing EPSG axis order mess in raster space would seem to be
> foolish to me and cause major annoyances. Performance-wise, processing
> flipped rasters with classic algorithms that process line per line would be
> terrible as soon as they are large enough, since reading each line would in
> practice require to read the whole raster each time.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> Check out the vibrant tech community on one of the world's most
> engaging tech sites, Slashdot.org! http://sdm.link/slashdot
> Geoserver-devel mailing list
> Geoserver-devel at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-devel
Ing. Andrea Aime
@geowolf
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
phone: +39 0584 962313
fax: +39 0584 1660272
mob: +39  339 8844549
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170410/72118399/attachment.html>
