[gdal-dev] Binary of the latest released GDAL for travis?
Angelos Tzotsos gcpp.kalxas at gmail.com
Tue Apr 11 03:28:32 PDT 2017
In that case, you are either using a ppa mixed environment (perhaps you
use the postgres ppa?) or you are using a package that still depends on
the upstream gdal version.
On 04/11/2017 01:22 PM, Ari Jolma wrote:
> 11.04.2017, 13:05, Angelos Tzotsos kirjoitti:
>> Hi Ari,
>> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable
>> sudo apt-get update
>> sudo apt-get install libgdal-dev
>> This should do it.
> No. I tried that before (found it in my .travis.yml file...) and it
> pulls in older version 1.10.0.
> Ari
>> Cheers,
>> Angelos
>> On 04/11/2017 11:05 AM, Ari Jolma wrote:
>>> 11.04.2017, 10:49, Bas Couwenberg kirjoitti:
>>>> On 2017-04-11 09:30, Ari Jolma wrote:
>>>>> How could I pull into travis the binaries of the latest released GDAL
>>>>> (now 2.1.3)?
>>>>> There seems to be experimental debian package
>>>>> https://packages.debian.org/experimental/libgdal-dev
>>>>> Does anybody have experience with them?
>>>> OSGeo-Live includes these packages, (re)built for Ubuntu xenial.
>>>>> Right now I'm pulling in the source code and building it in the
>>>>> overall build but that's really slow.
>>>> The ubuntugis-unstable PPA has the GDAL 2.1.3 packages for xenial
>>>> too (from OSGeo-Live), you can add the PPA in the travis setup
>>>> script and install the packages from there.
>>> What's the package name I should use?
>>> sudo add-apt-repository ppa:ubuntugis/ubuntugis-unstable -y
>>> gpg: keyring `/tmp/tmp2gKbLJ/secring.gpg' created
>>> gpg: keyring `/tmp/tmp2gKbLJ/pubring.gpg' created
>>> gpg: requesting key 314DF160 from hkp server keyserver.ubuntu.com
>>> gpg: /tmp/tmp2gKbLJ/trustdb.gpg: trustdb created
>>> gpg: key 314DF160: public key "Launchpad ubuntugis-stable" imported
>>> gpg: Total number processed: 1
>>> gpg:               imported: 1  (RSA: 1)
>>> OK
>>> sudo apt-get update
>>> $ sudo apt-get install libgdal-dev_2.1.3
>>> Reading package lists... Done
>>> Building dependency tree
>>> Reading state information... Done
>>> E: Unable to locate package libgdal-dev_2.1.3
>>> E: Couldn't find any package by regex 'libgdal-dev_2.1.3'
>>> Ari
>>>> https://launchpad.net/~ubuntugis/+archive/ubuntu/ubuntugis-unstable/+packages
>>>> Kind Regards, Bas _______________________________________________
>>>> gdal-dev mailing list gdal-dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Angelos Tzotsos, PhD
>> Charter Member
>> Open Source Geospatial Foundation
>> http://users.ntua.gr/tzotsos
Charter Member
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170411/95a1d085/attachment.html>
