[gdal-dev] compiling gdal and linking with postgis
Sandeep Gupta gupta.sandeep at gmail.com
Fri Apr 14 08:10:34 PDT 2017
 I have tried three version of gdal but this problem exists:
 The gdal compiles fine but when I build postgis with the compiled
 gdal then I get following error:
 libtool: link: cannot find the library
`/home/vagrant/pisi/tmp/libjpeg-7.0-3/usr/lib/libjpeg.la'
 This dependency is coming from gdal and most likely from this file:
 gdal-2.1.3/.libs/libgdal.lai
 Which looks like this:
dependency_libs=' -lexpat
/home/vagrant/pisi/tmp/libpng-1.6.12-3/usr/lib/libpng.la
-L/home/vagrant/src/master-env/lib
-L/home/pgxxc/easybuild/software/shad
owfax-westmere/PostgreSQL/9.6.2-foss-2016b-Python-2.7.12/lib -lpq
-lpthread -lrt -L/apps/packages/math/epd/7.6-3/lib -lcurl
/home/vagrant/pisi/tmp/libxml2-2.9.2-2/usr/lib/libxml2.la -lz -ldl
/cm/shared/apps/gcc/
4.8.4/lib/../lib64/libstdc++.la'
 I didn't find anything in configure etc. that can turn off depndency
on vagrant/pisi.
Thanks.
san
