[gdal-dev] GDAL 2.2.0 beta 1 available
Kurt Schwehr schwehr at gmail.com
Fri Apr 14 15:22:27 PDT 2017
Done.  https://trac.osgeo.org/gdal/changeset/38022
On Fri, Apr 14, 2017 at 8:09 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On vendredi 14 avril 2017 07:59:43 CEST Kurt Schwehr wrote:
> > Even,
> > Thanks for your hard work!
> > I did a quick mac osx fink build and spot checks with autotest - build
> > looks good.
> > A quick check of NEWS:
> > Kakadu v7.9.1 works for me. The line "add support for Kakadu v7.8" should
> > probably be something like:
> > add support for Kakadu v7.9.1. v7.8 should not be used. It has a bug
> > fixed in v7.9.
> > Should be 9.0:
> > OGRSpatialReference:
> > * Upgrade to EPSG database v8.9 <----- Upgrade to EPSG database v9.0
> > (#6772)
> I let you commit those changes and any other you may find appropriate? It
> certainly needs double checking.
> Eve
> Spatialys - Geospatial professional services
> http://www.spatialys.com
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170414/ba468167/attachment.html>
