[gdal-dev] GDAL 2.2.0beta1 and old poppler libraries
Even Rouault even.rouault at spatialys.com
Sun Apr 16 12:55:05 PDT 2017
On dimanche 16 avril 2017 20:31:09 CEST Andrew C Aitchison wrote:
> GDAL 2.2.0 beta1
> Scientific Linux 6 (= CentOS6 =  Red Hat EL 6).
> g++ 4.9.2 and g++ 5.3.1
> gdal-2.2.0/frmts/pdf/pdfdataset.cpp does not compile on my
> Scientific Linux 6 (= CentOS6 =  Red Hat EL 6) machine.
> pdfio.h lines 87-90:
>     private:
>          /* Added in poppler 0.15.0 */
>          virtual GBool hasGetChars() override;
>          virtual int getChars(int nChars, Guchar *buffer) override;
You can just remove the override qualifier in the above methods. Supporting properly this old
version could be done but would be quite tedious. An alternative would be that you disable C
++11 compilation mode with ./configure --without-cpp11 (you will loose the CAD driver then)
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170416/25894e76/attachment.html>
