[gdal-dev] Vector Tiles in OGR
Stefan Keller sfkeller at gmail.com
Mon Apr 17 03:39:55 PDT 2017
Hi Even,
We - Martin Boos (new in Cc) and I - are definitely thinking about
implementing an option for spatial bounds.
Youmay know e.g. this WFS option of QGIS?
 „[_] Only request features overlapping the view extent“
What would you prefer: The same behaviour as for the WFS provider, or
taking a fixed bounds which aren't following users pan/zoom actions
(unless the user explicitly resets the bounds)?
:Stefan
@Blake: We are very interested in you opinion regarding handling of
keys "crs" and "bounds" now as well as part of the future TileJSON
spec.
---------- Forwarded message ----------
Date: 2017-04-17 11:44 GMT+02:00
Subject: Re: [gdal-dev] Vector Tiles in OGR
To: Stefan Keller <sfkeller at gmail.com>
Cc: Gdal-Dev <gdal-dev at lists.osgeo.org>, Flippmoke
<flippmoke at gmail.com>, Even Rouault <even.rouault at mines-paris.org>,
petr.pridal at klokantech.com
Hi Stefan,
> P.S. @Even: Any news on a GDAL/OGR MVT reader?
No activity on this front as far as I know. There was a possible
funding opportunity recently for a project that would have involved
integating such a driver with QGIS, but the odds for it to come true
seems to be very low according to the latest updates I got.
And your plugin might actually solve the needs of this project !
Quick question: from my test of the plugin, I see it converts the
whole mbtiles and optionally merges geometry chunks of the same
feature spread over several tiles into a single geometry, right ? In
the preliminary discussions for the project I mentionned, it was not
clear if there was a need for doing just a decoding & rendering of
tiles that intersect the window of interest (could make sense if using
very large mbtiles or using remote tiles), instead of a whole mbtiles
conversion. Partial decoding, with merging of the tiles intersecting
the window of interest, seems to be a bit at odds with the (implicit
?) assumptions of the QGIS vector layers that assume that the geometry
of a feature will always be the same when it is returned, and not
clamped to the window of interest.
Even
> 2016-01-31 23:22 GMT+01:00 Flippmoke <flippmoke at gmail.com>:
> > All,
> > The first thing that is going to be required likely is a good generic c++
> > library for encoding and decoding vector tiles IMO.
> > I have spent a lot of time working on developing the mapnik vector tile
> > library to be a solid implementation, especially around all the work done
> > for 2.0 of Mapbox vector tile specification. I would love to eventually
> > help make this a generalized implementation so that it is portable to a
> > library like GDAL.
> > We have talked about doing something like this at Mapbox but will require
> > a good deal of time, so it hasn't been pushed forward yet. The other
> > issues that come to mind to me is that some of the libraries that mapnik
> > vector tile depends upon most likely need good custom implementations if
> > we wanted to make it more generic.
> > The reason for this is that I would prefer for it to be a header only
> > library with no dependencies. Adding more dependencies for GDAL seems
> > like it could be a mess.
> > Blake Thompson
> >> On Jan 31, 2016, at 10:10 AM, Stefan Keller <sfkeller at gmail.com> wrote:
> >> Hi Petr, Blake, Even and everybody
> >> I'm (besides Petr) the other maintainer of OSM2VectorTiles.
> >> I'd already asked Even a similar question.
> >> I'm advising now an intern to implement such a MVT Vector Tiles reader
> >> client in Python if possible as part of a QGIS plugin.
> >> And I'm interested not to do redundant implementations.
> >> Are there any news on this matter?
> >> :Stefan
> >> Prof. at HSR and leader of Geometa Lab
> >> @Even: Regarding OGR MVT development can you send to me (directly) a
> >> contact name of the group which won the bidding?
> >> 2016-01-06 15:24 GMT+01:00 Petr Pridal <petr.pridal at klokantech.com>:
> >>> Hi everybody,
> >>> thanks for the comments. Regarding the technical details:
> >>>> Each Tile is its own discrete dataset therefore the hardest part would
> >>>> be
> >>>> merging of features into the original features across tiles. You could
> >>>> use
> >>>> some complicated merging technique, but that could be very expensive.
> >>> The driver could require "id" parameter, which specifies name of an
> >>> attribute with unique identifier on the features shared across the
> >>> tiles.
> >>> Both MapBox vector tiles and OSM2VectorTiles tiles have an unique
> >>> non-zero
> >>> "osm_id" in place. The first version of driver could read only features
> >>> with such ID. The identifier does not have to be always filled, but
> >>> often it is, especially in deeper zoom levels derived purely from
> >>> OpenStreetMap - but yeh, a completely general stitching would be much
> >>> harder.
> >>> The clipping + merging of shapes itself can be implemented with
> >>> underlaying
> >>> GEOS library functions.
> >>> BTW It is possible to examine vector tiles data in pure JavaScript X-Ray
> >>> viewer (no WebGL support on browser required) made in OpenLayers3:
> >>> http://klokantech.github.io/ol3-sandbox/vector/xray.html
> >>> or with WebGL-enabled webbrowser with higher performance MapBox GL JS
> >>> powered X-Ray:
> >>> http://klokantech.github.io/mapbox-gl-js-offline-example/xray.html
> >>> A debug viewer for each vector tile (made in OL3) decoded in pure
> >>> JavaScript:
> >>> http://klokantech.github.io/ol3-sandbox/vector/tile-inspector.html
> >>> The OGR driver could be also practical for the unsimplified /
> >>> ungeneralised
> >>> MBTiles with OSM data available at:
> >>> http://osmlab.github.io/osm-qa-tiles/
> >>>> If you wanted to simply view vector tile data it could get confusing as
> >>>> well since most vector tiles need a buffer when they are used for
> >>>> visualization programs. This is important for things like labeling on
> >>>> maps
> >>>> etc. Therefore, you could get a large amount of overlapping data on
> >>>> tiles if you loaded them all in at once.
> >>> Clipping on border of each tile must be applied before stitching the
> >>> vector
> >>> features together - so the buffer is removed. Buffer is there only for
> >>> visualisation and labeling.
> >>>> As far as writing a simple decoder -- the mapnik-vector-tile decoder
> >>>> isn't
> >>>> currently able to decode vector tiles into a form not supported by
> >>>> mapnik.
> >>>> Therefore, OGR would not be able to easily use this.
> >>> Correct. It can't be used directly (GDAL can't link against), but the
> >>> relevant code can be extracted and reused directly. For basic decoding
> >>> critical is the Protobuf library (which is already in GDAL) and
> >>> https://github.com/mapbox/mapnik-vector-tile/blob/master/proto/vector_ti
> >>> le.proto + the code for converting pixel coordinates in features to
> >>> relevant geo coordinates and GEOS-based merging of features.
> >>>> We plan to write a generalized encoder and decoder eventually so that
> >>>> any
> >>>> other library can plugin with out the mapnik requirement.
> >>> This would be amazing.
> >>>> If you have any questions specifically about Mapnik Vector Tile or the
> >>>> Mapbox Vector Tile Specification feel free to ask me. I would note that
> >>>> you
> >>>> guys will want to update your vector tiles once the V2 specification
> >>>> changes are into Mapnik-Vector-Tile.
> >>> Cool! Thanks. Our world tiles are generated via Docker containers on a
> >>> cluster of computers - using Mapnik via Tilelive directly - so upgrades
> >>> on
> >>> Mapnik-Vector-Tile will propagate to the open-source rendering software.
> >>> I expect V2 spec will mean also new MapBox Streets V7, right?
> >>>> I see you mention MVT in MBTiles. Is it a recognized practice ? I don't
> >>>> see
> >>>> mention of that neither in the MVT spec (
> >>>> https://github.com/mapbox/vector-
> >>>> tile-spec/tree/master/2.0 ) nor the MBTiles one (
> >>>> https://github.com/mapbox/mbtiles-spec/blob/master/1.2/spec.md ),
> >>>> although
> >>>> I
> >>>> guess it is just a matter of storing a MVT blob in the tile_data
> >>>> column.
> >>> Yes. MapBox Studio Classic generates such MBTiles with Vector Tiles
> >>> inside - and Mapnik reads them directly when rasterising. Storing the
> >>> vector tiles in SQLite make sense - and it simplifies deployment, and
> >>> you can then easily have complete world on each node of a cluster of
> >>> tileservers. If you don't want to upgrade your base map too often, this
> >>> approach is pretty efficient and removes the centralised database as
> >>> typical bottleneck.
> >>> I did some tests on vector tiles vs raster in MBTiles and documented
> >>> these
> >>> in README.md at and https://github.com/klokantech/vector-tiles-sample
> >>> before we started to work on OSM2VectorTiles project.
> >>> There are also sample data and offline MapBox GL JS viewer in that repo.
> >>> Vector tiles can be hosted also "unpacked", just as files in folders on
> >>> a
> >>> standard web server - exactly like GDAL2Tiles or MapTiler.com does by
> >>> default for raster tiles.
> >>> If OGR driver is implemented, the primary source should be probably
> >>> reading
> >>> from an URL via curl.
> >>> Reading PBFs from an MBTiles (or another SQLite) is just the most
> >>> practical
> >>> portable alternative to it.
> >>> Technically people may store the tiles in different ways - for example
> >>> Wikimedia guys (http://maps.wikimedia.org/ and
> >>> https://github.com/kartotherian/) use Cassandra for tile storage, I
> >>> guess
> >>> MapBox internally is also on a different storage for production servers
> >>> for transfers and streaming tilesets there is the - but tiles are
> >>> ALWAYS
> >>> exposed via HTTP.
> >>> Regards,
> >>> Petr
> >>> Petr Pridal, Ph.D.
> >>> CEO
> >>> Klokan Technologies GmbH
> >>> Hofnerstrasse 98, 6314 Unterageri, Switzerland
> >>> Tel: +41 (0)41 511 26 12
> >>> Email: info at klokantech.com
> >>> Web: http://www.klokantech.com/
> >>> _______________________________________________
> >>> gdal-dev mailing list
> >>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
