[gdal-dev] GDAL 2.2.0 beta 1 available
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue Apr 18 10:06:13 PDT 2017
On 2017-04-18 1:56 PM, Jeff McKenna wrote:
> On 2017-04-18 1:50 PM, Jeff McKenna wrote:
>> On 2017-04-14 5:10 AM, Even Rouault wrote:
>>> I have prepared the GDAL/OGR 2.2.0 Beta 1 release. It will potentially
>>> be followed by a second beta, or directly by a RC1 if things go well.
>>> The source is available at:
>> Tested in the MS4W build environment on Windows, with VS 2015 and 2012.
>> No issues compiling or running with VS 2015.  With VS 2012 I get this
>> error right away when starting to compile (cpl_vsil_curl.cpp) :
>> https://pastebin.com/hBi6sv0c
>> -jeff
> I just noticed a very recent change (after beta1) to GDAL of "fix
> compilation with VS2015"  <--- this is confusing, as I just tested
> successfully VS2015 for the full MS4W build (includes netcdf-c-4.4.0,
> libkml, poppler, etc etc).  Maybe your recent change was not needed in
> my build environment?  odd.
> -jeff
Also note that I recently (January?) worked with the netcdf-c devs
regarding compiling issues with VisualStudio with their 4.4.1 release:
https://github.com/Unidata/netcdf-c/issues/304
anyway, that's now too much feedback from me here, ha!  :)
-jeff
