[gdal-dev] GDAL 2.2.0beta1 and old poppler libraries
Andrew C Aitchison andrew at aitchison.me.uk
Thu Apr 20 04:54:08 PDT 2017
On Sun, 16 Apr 2017, Even Rouault wrote:
> On dimanche 16 avril 2017 20:31:09 CEST Andrew C Aitchison wrote:
>> GDAL 2.2.0 beta1
>> Scientific Linux 6 (= CentOS6 =  Red Hat EL 6).
>> g++ 4.9.2 and g++ 5.3.1
>> gdal-2.2.0/frmts/pdf/pdfdataset.cpp does not compile on my
>> Scientific Linux 6 (= CentOS6 =  Red Hat EL 6) machine.
>> pdfio.h lines 87-90:
>>     private:
>>          /* Added in poppler 0.15.0 */
>>          virtual GBool hasGetChars() override;
>>          virtual int getChars(int nChars, Guchar *buffer) override;
> You can just remove the override qualifier in the above methods. Supporting properly this old
> version could be done but would be quite tedious.
I found an existing define which is true for poppler >= 0.16.
And have written a patch which leaves the override qualifier for
newer poppler libraries but disables it for very old ones.
Somewhere around 0.15 or 0.16 it will incorrectly remove the override
qualifier, but the code will still compile correctly.
Andrew C Aitchison
--- frmts/pdf/pdfio.h	2017/04/16 19:18:35
+++ frmts/pdf/pdfio.h	2017/04/19 14:32:02
@@ -85,9 +85,18 @@
         virtual void       close() override;
     private:
-        /* Added in poppler 0.15.0 */
+#ifdef POPPLER_BASE_STREAM_HAS_TWO_ARGS
+        /* getChars/hasGetChars added in poppler 0.15.0
+         * POPPLER_BASE_STREAM_HAS_TWO_ARGS true from poppler 0.16,
+         * This test will be wrong for poppler 0.15 or 0.16,
+         * but will still compile correctly.
+#else
+        virtual GBool hasGetChars() ;
+        virtual int getChars(int nChars, Guchar *buffer) ;
+#endif
         VSIPDFFileStream  *poParent;
         GooString         *poFilename;
