[gdal-dev] 2.2.0beta1 regression NULL values
    Even Rouault
    even.rouault at spatialys.com
    Fri Apr 21 01:54:26 PDT 2017
Hi Roger,
> See https://github.com/edzer/sfr/issues/309 - < 2.2.0 we could write
> "missing values" in vector drivers and read them back. In 2.2.0beta1, we
> see REAL "missing values" written out OK, but read back as numeric zero.
Did you check the output with ogrinfo/GDAL 2.2 to verify that they are indeed properly
written as missing ?
> We've only checked shapefiles and GPKG so far.
> Is this RFC 67?
Most likely
> Until now, rgdal code (and likely sf) has used:
>        case OFTReal:
>  	if (poFeature->IsFieldSet(iField))
>            REAL(ans)[iRow]=poFeature->GetFieldAsDouble(iField);
>  	else REAL(ans)[iRow]=NA_REAL;
>  	break;
> and the same for other field and list field types. Should we be using:
> int    CPL_DLL OGR_F_IsFieldSetAndNotNull( OGRFeatureH, int );
Yes
> and should we be writing:
> void   CPL_DLL OGR_F_SetFieldNull( OGRFeatureH, int );
> instead of leaving the field unset with for example:
>               if (!ISNA(NUMERIC_POINTER(VECTOR_ELT(ldata, j))[i]))
>                   poFeature->SetField( CHAR(STRING_ELT(fld_names, j)),
>                       NUMERIC_POINTER(VECTOR_ELT(ldata, j))[i] );
> that is jumping over features for which the field value coming from R is
> missing?
Leaving the field unset or setting it to Null with OGR_F_SetFieldNull() will have the same
effect for most drivers. For example the shapefile driver uses IsFieldSetAndNotNull()
internally on the write side, so both should result in the same result. The difference between
unset and setting to null will only be seen for JSon-based drivers or GML.
> We'd need to condition on GDAL version here (too), I guess.
> Was this regression intended?
There are indeed a few backward incompatible changes (that you've mentionned above) per
https://trac.osgeo.org/gdal/wiki/rfc67_nullfieldvalues that require user code changes.
Besides those intended changes, it is not impossible of course there's a real regression in
GDAL itself, but ideally you should try to isolate it from the Rgdal code, possibly through a
standalone C code or a GDAL Python script, so it can be more easily investigated
(unfortunately, I couldn't really make sense of the ticket you mentionned due to my
unfamiliarity with rgdal or sf). I'd also start by making sure where the issue is really: on the
read side, or the write side. For example by producing a shapefile/GPKG with rgdal/GDAL
2.1.3 and reading it with rgdal/GDAL 2.2, and the reverse.
Best regards,
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170421/6d111dce/attachment.html>
