[gdal-dev] GDAL 2.2.0 beta 2 available
Kurt Schwehr schwehr at gmail.com
Mon Apr 24 10:35:08 PDT 2017
Ouch.  My take is that caching headers like that should be very strongly
discouraged.  Maintaining code with people doing that really isn't a
reasonable proposition.
+1 going with 2) with filing a bug for someone else to do 3).
On Mon, Apr 24, 2017 at 10:20 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Hi,
> > - Shape: do not export Shapelib symbols for builds
> > --with-hide-internal-symbols (#6860)
> It turns out that the above change breaks QGIS 2.18 build, in particular
> the DXF2SHP converter native plugin, since it does a nasty trick: the QGIS
> build tree has the shapelib 2.10 includes files, but relies on linking
> against shapelib symbols exported by libgdal. The plugin apparently no
> longer exists in QGIS master, which builds fine against GDAL 2.2beta2.
> So I'm not sure what to do:
> 1) revert #6860 and export again shapelib symbols from GDAL. But this
> apparently breaks some other workflows
> 2) let distributions apply a patch to do this revert, while they use QGIS
> 2.18 or other code that depend on GDAL exporting shapelib symbols
> 3) Change DXF2SHP plugin to use OGR API instead of shapelib, but I'm not
> feeling like I would do that myself.
> My opinion would be to favor 2)
> Opinions ?
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170424/f1d7c23d/attachment.html>
