[gdal-dev] GDAL 2.2.0 beta 2 available
Sean Gillies sean at mapbox.com
Thu Apr 27 01:18:13 PDT 2017
Even,
I've sorted things out. As described in https://github.com/sgillies
/frs-wheel-builds/issues/15, I only need to change the
MACOSX_DEPLOYMENT_TARGET in my builds from 10.6 to 10.9 to build GDAL 2.2.0
(and distribute Python wheels that include it). Sorry, Mountain Lion
holdouts!
Rasterio is fine with GDAL 2.2.0beta2 except in a couple tests that check
reprojection of a geometry that straddles the antimeridian. Whether to cut
used to be optional, defaulting to false, but after
https://trac.osgeo.org/gdal/changeset/35964 is true and no longer optional.
https://github.com/OSGeo/gdal/blob/trunk/gdal/NEWS#L496
On Wed, Apr 26, 2017 at 1:05 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Sean,
> > I'd love to be able to build 2.2.0 on this slightly out of date compiler,
> > but if 2.2.0 will require C++11, I'll get with the program.
> 2.2.0 doesn't rquire C++11
> It seems that this compiler undefines the C99 isnan() macro in all cases
> as soon as <cmath> is included.
> Can you revert all the changes of your tree and apply the attached patch ?
> --without-cpp11 will probably still be needed.
> If that doesn't work, can you send the output of the following:
> gcc -dM -E - < /dev/null
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
Sean Gillies
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170427/f98414ea/attachment-0001.html>
