[gdal-dev] Fwd: [Projects] please create a new project flyer for your project with the new branding till FOSS4G Boston
Jeff McKenna jmckenna at gatewaygeomatics.com
Sat Aug 5 14:13:26 PDT 2017
Luca: I have taken Even's feedback and made some more text changes, and
also added a hillshade DEM (of Frank's home area in Canada) created
through GDAL 2.2.1 on my machine.  It creates a big SVG now, but
you/designer can decide to keep that image or not.
http://www.gatewaygeomatics.com/dl/gdal_a4.svg
PS. I created it using LibreOffice!
-jeff
On 2017-08-04 11:22 AM, Even Rouault wrote:
> On vendredi 4 août 2017 14:31:24 CEST Luca Delucchi wrote:
>  > On 28 July 2017 at 17:38, Even Rouault <even.rouault at spatialys.com>
> wrote:
>  > > Hi,
>  > Hi,
>  > > Is someone interested in creating a flyer for GDAL ? See below
>  > I worked on the flyer, but I need some more text and/or an image...
>  > You can see the draft here
>  > https://github.com/lucadelu/osgeo/blob/gdal/marketing/print/gdal_a4.svg
> Thanks a lot Luca for tackling this !
> A few observations/proposals:
> - wondering if the subtiltle "The Geospatial Data Translation Tools"
> shouldn't be replaced by the "The Geospatial Data Abstraction Library
> and translation tools" to get both the menaing of the acronym and the
> practical uses
> - perhaps replace "Welcome" by "Introduction" ?
> - in this paragraph, I would remove bold characters starting with "As a
> library"
> - I would replace "As a library, it is" by "It is writen in C++ and"
> - In the raster format list, I would add OGC WCS/WMS/WMTS.. And int the
> vector format list OGC WFS
> - I would replace in the vector formats "ESRI Personal Geodatabase" by
> "ESRI FileGeodatabase" since the latter is probably now more common than
> the former.
> - in the language list, Ruby and VB6 should be removed (no longer supported)
> - in "features", in the first bullet, I'd :
> * add after "image warping": "reprojection"
> * add after "merging": "tiling, DEM-related utilities (hillshading,
> slope, hypsometric rendernig)"
> - in the "Support for large files" bullet, I'd append "- with modest
> memory requirements"
> - in "where it is used", I'd removed OpenEV since the project is kind of
> dead now. In the "also utilized by" list, perhaps add gvSIG (to have at
> least one non C++ application)
> - I don't know if the white backgound of the GDAL logo is intentional.
> If not, you could start from the original SVG drawing that has not this
> background :
> https://svn.osgeo.org/gdal/trunk/gdal/data/GDALLogoColor.svg
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
