[gdal-dev] Raster statistics
Eric Wenger ARA/SED ewenger at ara.com
Tue Aug 8 13:22:01 PDT 2017
Paul,
You could call gdal_calc.py and pass it the numpy formulas on the command line…Otherwise it might be best to bring the raster in to OpenCV.
--Eric
From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Paul Meems
Sent: Thursday, August 03, 2017 2:51 PM
To: Chris Waigl
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Raster statistics
Thanks Chris for your reply.
I forgot to mention I'm not using GDAL with Python.
I use it with C++ and/or C#.
Paul
[http://www.bontepaarden.nl/bontepaarden/images/newButton.png]Paul Meems
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org<http://www.mapwindow.org/>
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl<http://www.mapwindow.nl/>
The MapWindow GIS project has moved to GitHub<https://github.com/MapWindow>!
Download the latest MapWinGIS mapping engine.<https://github.com/MapWindow/MapWinGIS/releases>
Download the latest MapWindow 5 open source desktop application.<https://github.com/MapWindow/MapWindow5/releases>
2017-08-03 20:05 GMT+02:00 Chris Waigl <cwaigl at alaska.edu<mailto:cwaigl at alaska.edu>>:
I would not use gdal for this particular task. I presume you have the band data in a 2D numpy array. Then I’d get the 80th percentile for example with np.percentile() and use a boolean expression to generate a mask for the array (droneraster > perc80value ).
Chris
Christine (Chris) Waigl - cwaigl at alaska.edu<mailto:cwaigl at alaska.edu> -  +1-907-474-5483<tel:(907)%20474-5483> - Skype: cwaigl_work
Geophysical Institute, UAF, 903 Koyukuk Drive, Fairbanks, AK 99775-7320, USA
On Aug 3, 2017, at 5:43 AM, Paul Meems <bontepaarden at gmail.com<mailto:bontepaarden at gmail.com>> wrote:
I have a drone raster file which I want to use for some calculation.
Before the calculation, I need to loose some extreme values.
I want to do something like a percentile calculation where you get all values, order them and loose the top 10%.
For this, I need to get all values first which can be slow when using a large file.
I looked at the statistics (band.GetStatistics) but that doesn't work well.
I thought I could use 2 times the standard deviation added to the mean to get roughly 97%.
But with these statistics:
    STATISTICS_MAXIMUM=33.186080932617
    STATISTICS_MEAN=24.840205979603
    STATISTICS_MINIMUM=1.5951598882675
    STATISTICS_STDDEV=4.7285348016053
Mean + 2*std is larger than the max.
So I moved to the histogram. It is also very fast, but I'm not sure how to use it.
I have this:
  256 buckets from 1.53322 to 33.248:
  410 77 66 66 65 58 56 45 42 87 57 72 61 65 68 70 73 82 93 ...
Does this mean, bucket 1 = 410 that I have 410 pixels of value 1.53322 and the second bucket means I have 77 pixels between 1.53322 and 1.657? 1.657 = 1.53322 + ((33.248 - 1.53322)/256)
Is this a good approach? Or can/should I use a different one.
Thanks,
Paul
gdal-dev mailing list
gdal-dev at lists.osgeo.org<mailto:gdal-dev at lists.osgeo.org>
https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170808/0f1e943a/attachment.html>
