[gdal-dev] How to drop a raster layer from GeoPackage?
Dmitry Baryshnikov bishop.dev at gmail.com
Tue Aug 22 03:03:44 PDT 2017
Is it the bug of gdalmanage that this utility cannot delete raster layer
from geopackage?
Best regards,
     Dmitry
22.08.17 12:49, Even Rouault пишет:
> On mardi 22 août 2017 09:42:40 CEST Rahkonen Jukka (MML) wrote:
> > Hi,
> > There is an interesting question in gis.stackexchange about how to
> remove a
> https://gis.stackexchange.com/questions/252782/remove-a-raster-from-geopack
> > age.
> > I had a try and gdalmanage did not have any effect on the GeoPackage
> > database but the workflow with ogrinfo works for me. Are there any other
> > alternatives?
> The manual ogrinfo way is the only one using GDAL utilities.
> We should probably extend the -sql "DELLAYER:xxxx" syntax to work with
> raster tables as well. Actually I see we currently also catch "DROP
> TABLE xxxx" to drop the table and remove links in other tables in the
> vector case (so with th same effect as DELLAYER:xxxxx). Would you mind
> creating an enhancement ticket about that ?
> There's ongoing work on the QGIS side (dev version only I guess) to
> offer in the DBManager a way to delete raster layers (issuing the SQL
> requests under the hood)
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170822/beb5407a/attachment.html>
