[gdal-dev] vsigzip woes with hgt.gz files
Vincent Schut schut at satelligence.com
Wed Aug 23 07:38:55 PDT 2017
On 08/23/2017 04:20 PM, Even Rouault wrote:
> On mercredi 23 août 2017 16:01:05 CEST Vincent Schut wrote:
> > Hi all,
> > I'm trying to get the /vsigzip/ driver working on srtm .hgt.gz files,
> > but I don't succeed:
> > gdalinfo /vsigzip/N37W105.hgt.gz
> > ERROR 4: `/vsigzip/N37W105.hgt.gz' not recognized as a supported file
> > format.
> > gdalinfo failed - unable to open '/vsigzip/N37W105.hgt.gz'.
> > This is with a .hgt.gz from here:
> > https://s3.amazonaws.com/elevation-tiles-prod/skadi/N37/N37W105.hgt.gz
> > gunzipping the file works OK.
> > Any hints?
> Fixed per https://trac.osgeo.org/gdal/ticket/7016
Thanks Even!
> However opening time is really slow (which might be a problem or not
> depending on what you're doing) as the whole file needs to be
> downloaded and decompressed. The reason is that .hgt files are pure
> raw data files without any header, so the only way to know the
> dimensions is to check the file size against 3601*3601*2 bytes (SRTM 3
> at low latitudes), 3601*1801*2 (SRTM 3 at high latitudes) or
> 1801*1801*2 (SRTM 1). But for a .gz file, the only way to get the
> uncompressed file size is to uncompress it...
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170823/1144b117/attachment.html>
