[gdal-dev] Which Proj.4 transforms are available in GDAL?
Joaquim Luis jluis at ualg.pt
Thu Aug 24 13:12:55 PDT 2017
Hi Even,
I'm implementing Proj.4 in GMT via GDAL and now, in the the testing stage,
I'm using data from
https://github.com/Beman/boost-trunk-git-svn/blob/master/libs/geometry/test_extensions/gis/projections/projections.cpp#L121
but to my surprise lots of projections are not implemented in GDAL. For
example
gdaltransform -s_srs EPSG:4326 -t_srs +proj=airy +ellps=WGS84 +units=m
ERROR 1: Translating source or target SRS failed:
+proj=airy
Or
gdaltransform -s_srs EPSG:4326 -t_srs +proj=bonne
ERROR 6: Failed to initialize PROJ.4 with `+proj=bonne +lon_0=0 +lat_1=0
+x_0=0 +y_0=0 +ellps=WGS84 +units=m +no_defs'.
Is there a place where I can find the list of available proj.4 transforms?
And also found some that do no agree between GDAL and proj. For example
echo 4.897 52.371 | proj +proj=vandg +ellps=WGS84 +units=m
489005.93       6431581.02
gdaltransform -s_srs EPSG:4326 -t_srs "+proj=vandg +ellps=WGS84 +units=m"
4.897 52.371
488459.293282675 6424391.46347316 0
Cheers
Joaquim
