[gdal-dev] Which Proj.4 transforms are available in GDAL?
Joaquim Luis jluis at ualg.pt
Fri Aug 25 10:25:36 PDT 2017
OK, understood thanks. But got confused too. Why would a GDAL port of a
proj.4 string do a different thing than the coded in the proj.4 string?
Found these two that not even with the +wktext agree
gdaltransform -s_srs EPSG:4326 -t_srs "+proj=aeqd +ellps=WGS84 +units=m
+wktext"
4.897 52.371
384537.462362467 5809944.80754693 0
echo 4.897 52.371 | proj +proj=aeqd +ellps=WGS84 +units=m
384923.72       5809986.5
gdaltransform -s_srs EPSG:4326 -t_srs "+proj=robin +ellps=WGS84 +units=m
+wktext"
4.897 52.371
394576.527707384 5570940.8420985 0
echo 4.897 52.371 | proj +proj=robin +ellps=WGS84 +units=m
394576.51       5571243.64
> Joaquim,
>> I'm implementing Proj.4 in GMT via GDAL and now, in the the testing
>> stage,
>> I'm using data from
>> https://github.com/Beman/boost-trunk-git-svn/blob/master/libs/geometry/test_
>> extensions/gis/projections/projections.cpp#L121
>> but to my surprise lots of projections are not implemented in GDAL. For
>> example
> GDAL SRS model is based on WKT, so only projections that have a mapping
> to WKT 1 (and for which a >developer cared enough to write the needed
> code !) are nominally supported
>> gdaltransform -s_srs EPSG:4326 -t_srs +proj=airy +ellps=WGS84 +units=m
> For unsupported projections, add +wktext. A dummy WKT representation is
> then built that captures >the full proj.4 string in a EXTENSION node.
> Can also serve for supported projections if you want to >overrite the
> WKT -> proj.4 string conversion done by GDAL
> $ gdalsrsinfo "+proj=airy +ellps=WGS84 +units=m +wktext"
> PROJ.4 : +proj=airy +ellps=WGS84 +units=m +wktext
> OGC WKT :
> PROJCS["unnamed",
>    GEOGCS["WGS 84",
>        DATUM["unknown",
>            SPHEROID["WGS84",6378137,298.257223563]],
>        PRIMEM["Greenwich",0],
>        UNIT["degree",0.0174532925199433]],
>    PROJECTION["custom_proj4"],
>    UNIT["Meter",1],
>    EXTENSION["PROJ4","+proj=airy +ellps=WGS84 +units=m +wktext"]]
> $ gdaltransform -s_srs EPSG:4326 -t_srs "+proj=airy +ellps=WGS84
> +units=m +wktext"
>> ERROR 1: Translating source or target SRS failed:
>> +proj=airy
>> Or
>> gdaltransform -s_srs EPSG:4326 -t_srs +proj=bonne
>> ERROR 6: Failed to initialize PROJ.4 with `+proj=bonne +lon_0=0 +lat_1=0
>> +x_0=0 +y_0=0 +ellps=WGS84 +units=m +no_defs'.
> I thing the issue is that lat_1=0 is invalid for bonne. Any non zero
> value is OK
>> Is there a place where I can find the list of available proj.4
>> transforms?
> You mean projections supported by GDAL (as far as I know, most if not
> all projections supported by >GDAL translate then to proj.4) ?
> Look at the various OSRSetXXXXX() methods in
> http://gdal.org/ogr__srs__api_8h.html
> Or starting there
> https://github.com/OSGeo/gdal/blob/trunk/gdal/ogr/ogr_srs_proj4.cpp#L616
>> And also found some that do no agree between GDAL and proj. For example
>> echo 4.897 52.371 | proj +proj=vandg +ellps=WGS84 +units=m
>> 489005.93       6431581.02
>> gdaltransform -s_srs EPSG:4326 -t_srs "+proj=vandg +ellps=WGS84
>> +units=m"
>> 4.897 52.371
>> 488459.293282675 6424391.46347316 0
> If you add --debug on, you'll see that GDAL adds a +R_A parameter. I
> haven't dug up into history to >know the reason for that.
> If you add +wktext, the original string will be passed unmodified to
> proj.4
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
