[gdal-dev] Fwd: [OpenJPEG] OpenJPEG 2.2.0 is out ! Faster and safer.
N. Farah nfarah at hotmail.com
Mon Aug 28 11:00:03 PDT 2017
Thanks Even for the quick response. I'll give it a try with setting OPJ_NUM_THREADS env variable to 8. Does it need to be used with GDAL_NUM_THREADS ? Any url to read about those two env variables ?
The two dataset i used:
<http://data.opengee.org/FusionTutorial-Full.tar.gz>
https://1drv.ms/u/s!AkFDoDHsFe7_hkBS6GbG4xMqnk6t<http://data.opengee.org/FusionTutorial-Full.tar.gz>
https://1drv.ms/u/s!AkFDoDHsFe7_hkG1-XDo7UztsPoC<http://data.opengee.org/FusionTutorial-Full.tar.gz>
p.s: i'm using GDAL 2.1.2
Noureddine
Sent: Monday, August 28, 2017 1:40:31 PM
To: N. Farah
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] Fwd: [OpenJPEG] OpenJPEG 2.2.0 is out ! Faster and safer.
> I rebuilt GDAL (older version: 2.1.2) using this new open jpeg 2.2.0
> (https://github.com/uclouvain/openjpeg/releases/download/v2.2.0/openjpeg-v2
> .2.0-linux-x86_64.tar.gz)
> and tried to convert two jp2 dataset to tiff (gdal_translate):
> - bluemarble_4km.jp2: (10800 x 5400 pixels). 37.3 mb file size.
> - usgsLanSat.jp2: (8627 x 7745 pixels). 48 mb file size.
Do you know if they use JPEG2000 tiling ?
> Tests were run on virtual machine with ‘Ubuntu 16.04’ operation system, 18
> gb RAM and 2 CPU processors.
> These results were not expected since the new openJpeg should be faster than
> the previous one. Could this be cause by 'gdal_translate' not using threads
> that the new openjpeg uses for performance boost ?
By default, GDAL will now enable openjpeg thread support. So you need to set the OPJ_NUM_THREADS environment variable. That said, you should already get significant performance improvements even without enabling multi-threading. I'm not sure why you don't get them.
I'd be interested if you could share those images.
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170828/3be1560c/attachment-0001.html>
