[gdal-dev] Generating Cloud Optimized GeoTIFFs
daunnc gr.pomadchin at gmail.com
Tue Aug 29 10:26:23 PDT 2017
> I suspect some issue with your setup
Thanks a lot, I agree that probably it's a software issue (breakpoint
helped), and my GDAL version is 2010100 (I commented out this version check
before as thought that it's not that important). Thanks again, and thanks
for your reply, I'll upgrade GDAL and hope problems would go, as commenting
this line out solves the problem and allows to validate tiff. Was really
confused by an API and happy that it was just my fault.
View this message in context: http://osgeo-org.1560.x6.nabble.com/Generating-Cloud-Optimized-GeoTIFFs-tp5332934p5332947.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
