[gdal-dev] Fwd: [OpenJPEG] OpenJPEG 2.2.0 is out ! Faster and safer.
Even Rouault even.rouault at spatialys.com
Wed Aug 30 00:38:12 PDT 2017
On mercredi 30 août 2017 00:25:46 CEST Nicholas G Lawrence wrote:
> I'm curious, why is OpenJpeg not compiled into GDAL by default? Is this a
> policy?
This is mostly a technical constraint. The GDAL OpenJPEG driver requires linking against
libopenjp2, which is the result of the compilation of the OpenJPEG source code, which is in
its own source code repository. So this is mostly an issue of packaging choice: which optional
dependencies you install before building GDAL. Like all other GDAL drivers that depend on
third party libraries. Most popular binary distributions of GDAL have the openjpeg driver built
(OSGeo4W, gisinternals, UbuntuGIS) (not necessarily against the latest libopenjp2 version)
The GDAL source code repository has historically a few copies of common dependencies (libz,
libtiff, etc...) for conveniency on platforms where installing packaged dependencies isn't easy
(Windows typically), but we cannot extend this practice to all dependencies, because of the
increased maintainance cost.
Even
> Thanks,
> Nick
> From: gdal-dev [mailto:gdal-dev-bounces at lists.osgeo.org] On Behalf Of Even
> Rouault Sent: Tuesday, 29 August 2017 7:37 PM
> To: gdal-dev at lists.osgeo.org
> Cc: jratike80 <jukka.rahkonen at maanmittauslaitos.fi>
> Subject: Re: [gdal-dev] Fwd: [OpenJPEG] OpenJPEG 2.2.0 is out ! Faster and
> safer.
> On mardi 29 août 2017 01:42:21 CEST jratike80 wrote:
> > N. Farah wrote
> > > The results you get when enabling multi-threading are very interesting:
> > > 26.s to 9.9 s. Then using the work in progress you end up with 1s.
> > > Basically a 26 times speed improvement.
> > Hi,
> > As always when you read benchmarks, you must keep the results and the
> > context together so it is clear what was tested. In this case the
> > important
> > part is that the test applies to single tiled images. They are what Kakadu
> > prefers (also in the usage examples) and it handles them splendidly by
> > utilizing the precincts. OpenJPEG has not been able to use precincts
> > (despite in a fork
> > https://lists.osgeo.org/pipermail/gdal-dev/2016-February/043650.html) and
> > therefore it has slow with single tiled images and actually useless if the
> > tile size is something like 20000 by 20000 pixels.
> > Even can say how much faster the new branch is with JPEG2000 images which
> > use 1024x1024 tiles but I suppose that the speed-up factor is much less
> > than
> > 26.
> For tiled images, the GDAL OpenJPEG driver currently still read whole tiles
> (perhaps this should be re-considered at some point), so sub-tile decoding
> improvements will not help here, and you won't get more than the
> improvements done during 2.2.0, so something like 20% for openjpeg
> single-threaded (your mileage may vary), or more if you enable
> OPJ_NUM_THREADS.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> WARNING: This email (including any attachments) may contain legally
> privileged, confidential or private information and may be protected by
> copyright. You may only use it if you are the person(s) it was
> intended to be sent to and if you use it in an authorised way. No one
> is allowed to use, review, alter, transmit, disclose, distribute, print
> or copy this email without appropriate authority.
> If this email was not intended for you and was sent to you by mistake,
> please telephone or email me immediately, destroy any hardcopies of
> this email and delete it and any copies of it from your computer
> system. Any right which the sender may have under copyright law, and
> any legal privilege and confidentiality attached to this email is not
> waived or destroyed by that mistake.
> It is your responsibility to ensure that this email does not contain
> and is not affected by computer viruses, defects or interference by
> third parties or replication problems (including incompatibility with
> your computer system).
> Opinions contained in this email do not necessarily reflect the
> opinions of the Department of Transport and Main Roads,
> or endorsed organisations utilising the same infrastructure.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170830/3a9e8f16/attachment-0001.html>
