[gdal-dev] gdal_translate: extracting mask band and its overviews
Emanuele Tajariol etj at geo-solutions.it
Thu Aug 31 09:55:54 PDT 2017
I'm trying and extract the single mask band out of a geotiff file using
gdal_translate.
The tiff file also contains overviews of mask band, and I'd like to extract them
as well (In the end of the mail there's a fragment of the input file's
gdalinfo.)
The command I'm using is:
gdal_translate -b mask \
   --config GDAL_TIFF_INTERNAL_MASK YES \
   -co COPY_SRC_OVERVIEWS=yes \
   -co TILED=yes  \
   -co COMPRESS=DEFLATE   \
   intput_file.tif output_mask.tif
Anyway the output file does not contain any overview at all.
I get the very same result also removing the GDAL_TIFF_INTERNAL_MASK config
(which should not be needed anyway since the mask band is exported as a data
band).
Am I missing any command line option or is it possibile at all?
   Thanks,
   Emanuele
Input file gdalinfo fragment:
Size is 19584, 19584
[...crs, origin, pixel size...]
Metadata:
  AREA_OR_POINT=Area
Image Structure Metadata:
  COMPRESSION=YCbCr JPEG
  INTERLEAVE=PIXEL
  SOURCE_COLOR_SPACE=YCbCr
[...Corner coords...]
Band 1 Block=256x256 Type=Byte, ColorInterp=Red
  Overviews: 9792x9792, 4896x4896, 2448x2448, 1224x1224, 612x612, 306x306
  Mask Flags: PER_DATASET
  Overviews of mask band: 9792x9792, 4896x4896, 2448x2448, 1224x1224, 612x612,
306x306
  Metadata:
    COLORINTERP=Red
Band 2 Block=256x256 Type=Byte, ColorInterp=Green
306x306
  Metadata:
    COLORINTERP=Green
Band 3 Block=256x256 Type=Byte, ColorInterp=Blue
306x306
  Metadata:
    COLORINTERP=Blue
[end]
Output file gdalinfo fragment:
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=DEFLATE
  INTERLEAVE=BAND
Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
[end]
Regards,
Emanuele Tajariol
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V
for more information.
Ing. Emanuele Tajariol
Technical Lead
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 1660272
http://www.geo-solutions.it
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro utilizzo
è consentito esclusivamente al destinatario del messaggio, per le finalità
indicate nel messaggio stesso. Qualora riceviate questo messaggio senza
esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-
mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal
Vostro sistema. Conservare il messaggio stesso, divulgarlo anche in parte,
distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse,
costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely for the
attention and use of the named addressee(s) and may be confidential or
proprietary in nature or covered by the provisions of privacy act (Legislative
Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not
in accord with its purpose, any disclosure, reproduction, copying,
distribution, or either dissemination, either whole or partial, is strictly
forbidden except previous formal approval of the named addressee(s). If you
are not the intended recipient, please contact immediately the sender by
telephone, fax or e-mail and delete the information in this message that has
been received in error. The sender does not give any warranty or accept
liability as the content, accuracy or completeness of sent messages and
accepts no responsibility  for changes made after they were sent or for other
risks which arise as a result of e-mail transmission, viruses, etc.
