[gdal-dev] Mass-conversion from NULL to nullptr ready to land
Kurt Schwehr schwehr at gmail.com
Sun Dec 10 08:15:18 PST 2017
+1 for landing it
On Dec 10, 2017 6:24 AM, "Mateusz Loskot" <mateusz at loskot.net> wrote:
> On 10 Dec 2017 14:52, "Even Rouault" <even.rouault at spatialys.com> wrote:
> (*) sed "s/NULL/nullptr/g" is not an option, as there is a significant
> number of occurences of NULL being in a string (think to SQL statements).
> clang-tidy works great, but as it does a true parsing of the code, you
> need to pass it the same -D and -I switches as the compiler would take. I
> guess there would perhaps be a way of creating a CXX script that could be
> used as a fake compiler and would redirect to clang-tidy.
> Even, best results clang-tidy delivers if used with clang compile database
> (JSON file). Its easy to generate one with CMake, but that's obviously not
> an (convenient) option for GDAL.
> Have you tried Bear instead?
> https://github.com/rizsotto/Bear
> It can intercept compile commands from any build system on Linux.
> Mateusz
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171210/7f5b4786/attachment-0001.html>
