[gdal-dev] [gdal-commits] r41044 - trunk/gdal/port
Kurt Schwehr schwehr at gmail.com
Fri Dec 15 13:49:32 PST 2017
Ugh.  constexpr would be nice to get started on, but yes, many of the wins
come in more with C++14 and C++17.
https://ci.appveyor.com/project/OSGeo/gdal/build/1.0.4152/job/y7fusq8a4lopxpni
Environment: platform=x86, VSCOMNTOOLS=$(VS120COMNTOOLS), SDK=release-1800,
MSVC_VER=1800
cpl_error.cpp
c:\projects\gdal\gdal\port\cpl_conv.cpp(343) : error C2144: syntax error :
'char' should be preceded by ';'
c:\projects\gdal\gdal\port\cpl_conv.cpp(343) : error C4430: missing type
specifier - int assumed. Note: C++ does not support default-int
c:\projects\gdal\gdal\port\cpl_conv.cpp(344) : error C2144: syntax error :
c:\projects\gdal\gdal\port\cpl_conv.cpp(344) : error C4430: missing type
c:\projects\gdal\gdal\port\cpl_conv.cpp(344) : error C2086: 'int constexpr'
: redefinition
        c:\projects\gdal\gdal\port\cpl_conv.cpp(343) : see declaration of
'constexpr'
c:\projects\gdal\gdal\port\cpl_conv.cpp(669) : error C2146: syntax error :
missing ';' before identifier 'size_t'
missing ';' before identifier 'nChunkSize'
c:\projects\gdal\gdal\port\cpl_conv.cpp(669) : error C2275: 'size_t' :
illegal use of this type as an expression
        c:\projects\gdal\gdal\port\predefined c++ types (compiler
internal)(19) : see declaration of 'size_t'
c:\projects\gdal\gdal\port\cpl_conv.cpp(669) : error C2065: 'nChunkSize' :
undeclared identifier
c:\projects\gdal\gdal\port\cpl_conv.cpp(670) : error C2065: 'nChunkSize' :
c:\projects\gdal\gdal\port\cpl_conv.cpp(682) : error C2065: 'nChunkSize' :
c:\projects\gdal\gdal\port\cpl_conv.cpp(691) : error C2065: 'nChunkSize' :
c:\projects\gdal\gdal\port\cpl_conv.cpp(702) : error C2065: 'nChunkSize' :
c:\projects\gdal\gdal\port\cpl_conv.cpp(702) : error C2660: 'VSIFReadL' :
function does not take 3 arguments
c:\projects\gdal\gdal\port\cpl_conv.cpp(709) : error C2065: 'nChunkSize' :
c:\projects\gdal\gdal\port\cpl_conv.cpp(760) : error C2065: 'nChunkSize' :
c:\projects\gdal\gdal\port\cpl_conv.cpp(1987) : error C2144: syntax error :
c:\projects\gdal\gdal\port\cpl_conv.cpp(1987) : error C4430: missing type
c:\projects\gdal\gdal\port\cpl_conv.cpp(1987) : error C2086: 'int
constexpr' : redefinition
'constexpr'
c:\projects\gdal\gdal\port\cpl_conv.cpp(1988) : error C2144: syntax error :
'double' should be preceded by ';'
c:\projects\gdal\gdal\port\cpl_conv.cpp(1988) : error C4430: missing type
c:\projects\gdal\gdal\port\cpl_conv.cpp(1988) : error C2086: 'int
'constexpr'
c:\projects\gdal\gdal\port\cpl_conv.cpp(2608) : error C2146: syntax error :
missing ';' before identifier 'nBufferSize'
c:\projects\gdal\gdal\port\cpl_conv.cpp(2608) : error C2275: 'size_t' :
c:\projects\gdal\gdal\port\cpl_conv.cpp(2608) : error C2065: 'nBufferSize'
: undeclared identifier
c:\projects\gdal\gdal\port\cpl_conv.cpp(2609) : error C2065: 'nBufferSize'
c:\projects\gdal\gdal\port\cpl_conv.cpp(2624) : error C2065: 'nBufferSize'
c:\projects\gdal\gdal\port\cpl_conv.cpp(2631) : error C2065: 'nBufferSize'
cpl_string.cpp
cplstring.cpp
On Fri, Dec 15, 2017 at 9:22 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> Kurt,
> It doesn't look like constexpr is available in VS2013 (at least not in all
> sub-versions of it):
> https://stackoverflow.com/questions/20264644/constexpr-
> not-compiling-in-vc2013
> Personnally, I don't see it as a super needed feature that would justify
> dropping VS2013 support. Especially in the below use cases where it doesn't
> bring anything more than const, except more characters to type/read. I'd
> bet any sane compiler in -O2 will compile the source to the same machine
> code in all those cases
> Even
> On vendredi 15 décembre 2017 07:04:23 CET you wrote:
> > Author: goatbar
> > Date: 2017-12-15 07:04:23 -0800 (Fri, 15 Dec 2017)
> > New Revision: 41044
> > Modified:
> > trunk/gdal/port/cpl_conv.cpp
> > Log:
> > const -> constexpr for things known at compile time in cpl_conv.cpp
> > Modified: trunk/gdal/port/cpl_conv.cpp
> > --- trunk/gdal/port/cpl_conv.cpp 2017-12-15 14:37:43 UTC (rev 41043)
> > +++ trunk/gdal/port/cpl_conv.cpp 2017-12-15 15:04:23 UTC (rev 41044)
> > @@ -340,8 +340,8 @@
> > // ASCII characters.
> > -static const char knLF = 10;
> > -static const char knCR = 13;
> > +constexpr char knLF = 10;
> > +constexpr char knCR = 13;
> > * Reads in at most one less than nBufferSize characters from the fp
> > @@ -666,7 +666,7 @@
> > /* the line. */
> > char *pszRLBuffer = nullptr;
> > - const size_t nChunkSize = 40;
> > + constexpr size_t nChunkSize = 40;
> > char szChunk[nChunkSize] = {};
> > size_t nChunkBytesRead = 0;
> > int nBufLength = 0;
> > @@ -1984,8 +1984,8 @@
> > /* CPLDMSToDec() */
> > -static const char *sym = "NnEeSsWw";
> > -static const double vm[] = { 1.0, 0.0166666666667, 0.00027777778 };
> > +constexpr char sym[] = "NnEeSsWw";
> > +constexpr double vm[] = { 1.0, 0.0166666666667, 0.00027777778 };
> > /** CPLDMSToDec */
> > double CPLDMSToDec( const char *is )
> > @@ -2605,7 +2605,7 @@
> > /* Prepare buffer. */
> > - const size_t nBufferSize = 1024 * 1024;
> > + constexpr size_t nBufferSize = 1024 * 1024;
> > GByte *pabyBuffer = static_cast<GByte
> > *>(VSI_MALLOC_VERBOSE(nBufferSize)); if( pabyBuffer == nullptr )
> > gdal-commits mailing list
> > gdal-commits at lists.osgeo.org
> > https://lists.osgeo.org/mailman/listinfo/gdal-commits
> Spatialys - Geospatial professional services
> http://www.spatialys.com
http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171215/41510862/attachment.html>
