[gdal-dev] ogr2ogr from MySQL to FileGDB not working correctly in	2.x
    Thanny
    thannyd at earthlink.net
    Mon Dec 18 20:26:26 PST 2017
I hope this is the correct place to post about this.
There are several use cases I have for moving data into MySQL for
processing, then exporting back out to ESRI FileGDB, using the ogr2ogr
utility.
Long story short, if I use a GDAL 1.x install, I'm able to export from MySQL
to FileGDB without issue (at least mostly - the PROMOTE_TO_MULTI geometry
type doesn't work, though it previously did).  If I use a GDAL 2.x install,
the export works only for attribute data.  At the beginning of the export,
this error is printed:
ERROR 6: CreateGeomField() not supported by this layer.
I've reproduced this with both polygon and point layers.
As I said, I've used many different distributions, and all have this
problem.  Here's the FileGDB line from "ogrinfo --formats":
  FileGDB -vector- (rw+): ESRI FileGDB
Any ideas on what I can do to narrow down where the problem is?
Sent from: http://osgeo-org.1560.x6.nabble.com/GDAL-Dev-f3742093.html
