[gdal-dev] port/md5 cvs_MD5*
Ari Jolma ari.jolma at gmail.com
Wed Dec 20 15:01:01 PST 2017
Dmitry Baryshnikov kirjoitti 21.12.2017 klo 08:58:
> Hi Ari,
> The pull request and discussion can be found here:
> https://github.com/OSGeo/gdal/pull/280
Yes. Sorry. I didn't see that. Maybe Kurt also didn't see that - or the
aspect of it that he brought up here. Maybe a place for some
institutional improvements.
> I cannot imagine that this improvements will affect something else.
> MD5 used for cache paths initially, I only added some improvements for
> WMS cache size limits, expire time and split cache per dataset base
> (i.e. to delete cached files when dataset deletes).
> What about your idea about common caching classes/functions - this is
> topic to discuss.
I needed a simple URL -> a few files cache for the WCS. Not much code
but probably other drivers need such functionality too. I didn't do good
research although I knew WMS has similar needs. The code is not much but
issues such as unique filenames and simultaneous access from
threads/processes add complication.
Ari
> Best regards,
>      Dmitry
> 21.12.2017 0:32, Ari Jolma пишет:
>> My comments on this:
>> 1) The MD5 function seems to be needed only(?) for the WMS cache and
>> probably also WFS. To me that highlights the need for some
>> integration work regarding caching in GDAL. I also implemented yet
>> another caching code for the WCS (without MD5). Looking at my
>> $HOME/.gdal I see also gmlas_xsd_cache and srs_cache.
>> 2) This discussion thread also highlights the need to go towards more
>> pull request style development at least for bigger changes.
>> Ari
>> Kurt Schwehr kirjoitti 21.12.2017 klo 02:56:
>>> Dmitry,
>>> Statements like this indicate a world of trouble:
>>> > I'm not sure that Python produce the same hash than cvs_MD5*.
>>> > Also I'm not sure what in future they will be the same.
>>> If you remove the swig and python stuff, move the CPLMD5String to
>>> cpl_md5.{cpp,h}, and follow Even's suggestions, I will be much
>>> happier with the change.  A C++ test would be good too. I'll be
>>> happy to do a quick fix up of a few things that I see in the md5
>>> code once it is to that point.  I do think it is a good thing that
>>> there be md5 support in port along with the existing sha{1,256} code.
>>> I see what you are saying about
>>> the OGRGeometry::exportTo{json,kml,gml}, but that doesn't (to me)
>>> support your argument.  My personal opinion is that GDAL would have
>>> been stronger if those had separate and not been a part of OGRGeometry.
>>> If there is a critical difference between CPLMD5String or a language
>>> and use case where md5 support in that language from GDAL is really
>>> required, you need to first document that issue.
>>> On Wed, Dec 20, 2017 at 7:46 AM, Dmitry Baryshnikov
>>> <bishop.dev at gmail.com <mailto:bishop.dev at gmail.com>> wrote:
>>>     Just the note that CPLMD5String not only for Python, but any other
>>>     API clients: C/C++, Java, Perl, etc.
>>>     But, I agree, it can be easily removed.
>>>     Best regards,
>>>         Dmitry
>>>     20.12.2017 18 <tel:20.12.2017%2018>:35, Even Rouault пишет:
>>>                 And why are you exposing this to python? Python has
>>>                 md5 hashing
>>>         already
>>>                 built in.
>>> cvs_MD5*.
>>>         I do hope they return the same thing. MD5 is a standardized
>>>         algorithm:
>>> https://tools.ietf.org/html/rfc1321
>>> <https://tools.ietf.org/html/rfc1321>
>>>         I'm not sure we really need to expose it our CPL MD5 through
>>>         Python.
>>>     _______________________________________________
>>>     gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
>>> http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20171221/c761703e/attachment.html>
