[gdal-dev] port/md5 cvs_MD5*
Dmitry Baryshnikov bishop.dev at gmail.com
Thu Dec 21 06:44:23 PST 2017
Hi Kurt,
In future I will try to write more detailed commit messages, and of
course, will point to the osgeo/gdal pull request on github.
By the way this situation shows the one more reason to switch to github,
as Even proposed.
Best regards,
     Dmitry
21.12.2017 16:57, Kurt Schwehr пишет:
> Dmitry,
> Thank you for doing https://trac.osgeo.org/gdal/changeset/41095
> Sorry, I didn't know about the pull request.  I get spammed by github
> notifications and have yet to figure out how make the 99.99% I don't care
> about go away. :|
> I think commits should always reference relevant issues and pull requests.
> The commit message here https://trac.osgeo.org/gdal/changeset/41086 was not
> particularly useful.  In reading that patch, I assumed that this was a code
> brand new to GDAL.  I filter out the changes for drivers that I don't use
> and the diffs never go through my repo (0.8M lines locally versus 1.8M in
> svn).  The description for r41085 never mentions migrating code from wms to
> port or the pr.
> On Wed, Dec 20, 2017 at 1:58 PM, Dmitry Baryshnikov <bishop.dev at gmail.com>
> wrote:
>> Hi Ari,
>> The pull request and discussion can be found here:
>> https://github.com/OSGeo/gdal/pull/280
>> I cannot imagine that this improvements will affect something else. MD5
>> used for cache paths initially, I only added some improvements for WMS
>> cache size limits, expire time and split cache per dataset base (i.e. to
>> delete cached files when dataset deletes).
>> What about your idea about common caching classes/functions - this is
>> topic to discuss.
>> Best regards,
>>      Dmitry
>> 21.12.2017 0:32, Ari Jolma пишет:
>> My comments on this:
>> 1) The MD5 function seems to be needed only(?) for the WMS cache and
>> probably also WFS. To me that highlights the need for some integration work
>> regarding caching in GDAL. I also implemented yet another caching code for
>> the WCS (without MD5). Looking at my $HOME/.gdal I see also gmlas_xsd_cache
>> and srs_cache.
>> 2) This discussion thread also highlights the need to go towards more pull
>> request style development at least for bigger changes.
>> Ari
>> Kurt Schwehr kirjoitti 21.12.2017 klo 02:56:
>> Dmitry,
>> Statements like this indicate a world of trouble:
>>> I'm not sure that Python produce the same hash than cvs_MD5*.
>>> Also I'm not sure what in future they will be the same.
>> If you remove the swig and python stuff, move the CPLMD5String to
>> cpl_md5.{cpp,h}, and follow Even's suggestions, I will be much happier with
>> the change.  A C++ test would be good too.  I'll be happy to do a quick fix
>> up of a few things that I see in the md5 code once it is to that point.  I
>> do think it is a good thing that there be md5 support in port along with
>> the existing sha{1,256} code.
>> I see what you are saying about the OGRGeometry::exportTo{json,kml,gml},
>> but that doesn't (to me) support your argument.  My personal opinion is
>> that GDAL would have been stronger if those had separate and not been a
>> part of OGRGeometry.
>> If there is a critical difference between CPLMD5String or a language and
>> use case where md5 support in that language from GDAL is really required,
>> you need to first document that issue.
>> On Wed, Dec 20, 2017 at 7:46 AM, Dmitry Baryshnikov <bishop.dev at gmail.com
>> <mailto:bishop.dev at gmail.com> <bishop.dev at gmail.com>> wrote:
>>      Just the note that CPLMD5String not only for Python, but any other
>>      API clients: C/C++, Java, Perl, etc.
>>      But, I agree, it can be easily removed.
>>      Best regards,
>>          Dmitry
>>      20.12.2017 18 <tel:20.12.2017%2018> <20.12.2017%2018>:35, Even
>> Rouault пишет:
>>                  And why are you exposing this to python?  Python has
>>                  md5 hashing
>>          already
>>                  built in.
>>          I do hope they return the same thing. MD5 is a standardized
>>          algorithm:
>>          https://tools.ietf.org/html/rfc1321
>>          <https://tools.ietf.org/html/rfc1321>
>>          I'm not sure we really need to expose it our CPL MD5 through
>>          Python.
>>      _______________________________________________
>>      gdal-dev mailing list
>>      gdal-dev at lists.osgeo.org <mailto:gdal-dev at lists.osgeo.org>
>> <gdal-dev at lists.osgeo.org>
>>      https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>      <https://lists.osgeo.org/mailman/listinfo/gdal-dev>
>> http://schwehr.org
>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/gdal-dev
