[gdal-dev] Question on 0th IFD offset when producing a JPEG-Compressed GeoTIFF (GDAL 1.11 vs 2.x)
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Wed Feb 1 04:04:03 PST 2017
Hi Even, another question.
What about the internal libtiff implementation?
There will be any difference in building against a system (released)
libtiff version with respect to the internal version?
Cheers,
Daniele
On Tue, Jan 31, 2017 at 6:34 PM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mardi 31 janvier 2017 18:29:48 CET Daniele Romagnoli wrote:
> > Hi Even,
> > I'm back to this topic and I have a couple of questions.
> > - Is it there any libtiff specific version involvement on that?
> > - Are all these improvements self contained in GDAL code itself or do
> them
> > require some specific libtiff version?
> Should probably work with any libtiff 4.0.X version
> > Cheers,
> > Daniele
> > On Fri, Dec 16, 2016 at 2:56 PM, Daniele Romagnoli <
> > daniele.romagnoli at geo-solutions.it> wrote:
> > > On Fri, Dec 16, 2016 at 2:48 PM, Even Rouault <
> > > wrote:
> > >> > Right,
> > >> > Indeed, before sending my previous email I have also tried with:
> > >> > *gdaladdo -r average --config COMPRESS_OVERVIEW DEFLATE --config
> > >> > PHOTOMETRIC_OVERVIEW RGB*
> > >> > to understand if it was related to JPEG only but, even with these
> > >> options,
> > >> > the output overviews were jpeg compressed (I assume there is some
> kind
> > >> of
> > >> > coherency check in gdaladdo).
> > >> With internal overviews, the _OVERVIEW configuration options are
> ignored.
> > >> Their value is deduced from the settings of the main IFD.
> > > It makes sense, indeed.
> > >> I don't think there's a strong technical reason for that. Mostly a
> side
> > >> effect of the fact that there are slightly different code paths to
> handle
> > >> creation of internal and external overviews, and the reading of
> _OVERVIEW
> > >> config options is done only in the external overview code path.
> > >> > > I do reproduce something similar to your findings in 2.1 indeed.
> This
> > >> no
> > >> > > longer happens in trunk due to related improvements (
> > >> > > https://trac.osgeo.org/gdal/wiki/CloudOptimizedGeoTIFF), I made
> in
> > >> the
> > >> > > last couple of weeks (using the same trick of creating a in-memory
> > >> TIFF
> > >> > > file to get the JPEG tables and set them direcly on the overview
> IFD
> > >> at
> > >> > > creation time).
> > >> > Do you think this will be available in other series or does it
> > >> > introduce
> > >> > new API/major changes which makes it available on 2.2.x only?
> > >> No API change, but this is in the improvement category rather than
> > >> bugfixing, and my first changeset resulted in some corrupted images in
> > >> some
> > >> situations, which was unnoticed for a few weeks, so that's a sign
> that it
> > >> is a somewhat risky change (the GeoTIFF driver is a complex beast),
> not
> > >> worth the trouble of breaking stable branches.
> > > Understood. thanks for the feedback.
> > > Cheers,
> > > Daniele
> > >> Even
> > >> Spatialys - Geospatial professional services
> > >> http://www.spatialys.com
> > > GeoServer Professional Services from the experts! Visit
> > > http://goo.gl/it488V for more information.
> > > Ing. Daniele Romagnoli
> > > Senior Software Engineer
> > > GeoSolutions S.A.S.
> > > Via di Montramito 3/A
> > > 55054 Massarosa (LU)
> > > Italy
> > > phone: +39 0584 962313 <+39%200584%20962313> <+39%200584%20962313>
> > > fax: +39 0584 1660272 <+39%200584%20166%200272>
> > > http://www.geo-solutions.it
> > > http://twitter.com/geosolutions_it
> > > *AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
> > > Le informazioni contenute in questo messaggio di posta elettronica e/o
> > > nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
> > > loro utilizzo è consentito esclusivamente al destinatario del
> messaggio,
> > > per le finalità indicate nel messaggio stesso. Qualora riceviate questo
> > > messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
> > > darcene notizia via e-mail e di procedere alla distruzione del
> messaggio
> > > stesso, cancellandolo dal Vostro sistema. Conservare il messaggio
> stesso,
> > > divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
> > > utilizzarlo per finalità diverse, costituisce comportamento contrario
> ai
> > > principi dettati dal D.Lgs. 196/2003.
> > > The information in this message and/or attachments, is intended solely
> for
> > > the attention and use of the named addressee(s) and may be
> confidential or
> > > proprietary in nature or covered by the provisions of privacy act
> > > (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection
> > > Code).Any use not in accord with its purpose, any disclosure,
> > > reproduction,
> > > copying, distribution, or either dissemination, either whole or
> partial,
> > > is
> > > strictly forbidden except previous formal approval of the named
> > > addressee(s). If you are not the intended recipient, please contact
> > > immediately the sender by telephone, fax or e-mail and delete the
> > > information in this message that has been received in error. The sender
> > > does not give any warranty or accept liability as the content,
> accuracy or
> > > completeness of sent messages and accepts no responsibility for changes
> > > made after they were sent or for other risks which arise as a result of
> > > e-mail transmission, viruses, etc.
GeoSolutions S.A.S.
Italy
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
does not give any warranty or accept liability as the content, accuracy or
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170201/c466afff/attachment-0001.html>
