[gdal-dev] Replace holes by multiple polygons
agerrius arno at agerrius.nl
Thu Feb 2 11:32:47 PST 2017
I'm trying to use polygons with holes in another application that does not
support the concept of holes. So my idea is to split the polygons with holes
into a number of polygons, so that the same shape can be represented without
using holes.
Does GDAL have any functionality for this kind of processing?
Thanks,
Arno
View this message in context: http://osgeo-org.1560.x6.nabble.com/Replace-holes-by-multiple-polygons-tp5306055.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
