[gdal-dev] Question on 0th IFD offset when producing a JPEG-Compressed GeoTIFF (GDAL 1.11 vs 2.x)
Daniele Romagnoli daniele.romagnoli at geo-solutions.it
Fri Feb 3 01:39:51 PST 2017
Hi Even,
Thanks for your feedback, as usual.
Cheers,
Daniele
On Fri, Feb 3, 2017 at 10:28 AM, Even Rouault <even.rouault at spatialys.com>
wrote:
> On mercredi 1 février 2017 13:04:03 CET Daniele Romagnoli wrote:
> > Hi Even, another question.
> > What about the internal libtiff implementation?
> > There will be any difference in building against a system (released)
> > libtiff version with respect to the internal version?
> The internal libtiff implementation is just libtiff CVS HEAD, so currently
> 4.0.8dev
> So it has generally a few more fixes than the last released version, but
> for the subject discussed here, using it or an external libtiff will not
> make a difference.
> Even
> Spatialys - Geospatial professional services
> http://www.spatialys.com
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
Ing. Daniele Romagnoli
Senior Software Engineer
GeoSolutions S.A.S.
Via di Montramito 3/A
55054  Massarosa (LU)
Italy
phone: +39 0584 962313
fax:      +39 0584 1660272
http://www.geo-solutions.it
*AVVERTENZE AI SENSI DEL D.Lgs. 196/2003*
nel/i file/s allegato/i sono da considerarsi strettamente riservate. Il
loro utilizzo è consentito esclusivamente al destinatario del messaggio,
per le finalità indicate nel messaggio stesso. Qualora riceviate questo
messaggio senza esserne il destinatario, Vi preghiamo cortesemente di
darcene notizia via e-mail e di procedere alla distruzione del messaggio
stesso, cancellandolo dal Vostro sistema. Conservare il messaggio stesso,
divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od
utilizzarlo per finalità diverse, costituisce comportamento contrario ai
information in this message that has been received in error. The sender
does not give any warranty or accept liability as the content, accuracy or
completeness of sent messages and accepts no responsibility  for changes
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170203/fc12d7ed/attachment-0001.html>
