[gdal-dev] Problem when using gdal_translate to create mbtiles
Even Rouault even.rouault at spatialys.com
Wed Feb 8 02:41:15 PST 2017
On mardi 7 février 2017 17:42:30 CET Renato Souza Sanabria wrote:
> Hi,
> I have two similar (but with different resolutions) .tif's that I'm trying
> to convert to .mbtiles with gdal_translate. They both have 4 bands (RGBA),
> but only one of them is converted correctly (all four bands). In the case
> of the other one, the Alpha band is not converted and is removed in the
> final file.
Guessing the number of bands in a MBTiles file is a guess, so sometimes it doesn't work out
of the box. Or it might be possible that the alpha channel of your dataset is always at 255.
You can try the BAND_COUNT open option:
http://gdal.org/frmt_mbtiles.html
*BAND_COUNT*=AUTO/1/2/3/4: Number of bands of the dataset exposed after opening.
Some conversions will be done when possible and implemented, but this might fail in some
cases, depending on the BAND_COUNT value and the number of bands of the tile. Defaults
to AUTO.
gdalinfo -oo BAND_COUNT=4 foo.mbtiles
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170208/ce95ddc2/attachment.html>
