[gdal-dev] Using the tables connection parameter correctly in ogr2ogr command for db with large number of tables with geometry columns.
Hemant Bist hemantbist at gmail.com
Wed Feb 8 16:01:37 PST 2017
Is it correct to pass dummy tables that don't exist in database to ogr2ogr
 command. It seems to work, but I am not sure it will work going forward(I
am currently using 1.9 most
of the work and 2.0 for some of the new code).
eg. I passed tables=tablename_that_does_not_exis   (a dummy table name that
does not exist) to following command. Note that I did not pass my_osm_data
at all to tables parameter. Is that correct?
ogr2ogr -s_srs EPSG:4326 -t_srs EPSG:4326 -f "ESRI Shapefile" '/tmp/ab.shp'
PG:"dbname=mydbname tables=tablename_that_does_not_exist" -sql " select *
from my_osm_data limit 1"
The reason I need to pass tables parameter is that without this the ogr2ogr
is very slow. The db has large number of tables with geomtery columns and
it seems to effectively query all geometry columns during startup. (And
passing the actual set of  tables used would require me to understand all
the sqls).
Thanks,
Hemant.
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170208/55405739/attachment.html>
