[gdal-dev] Can i modify existing coordinates data in GeoTiff using GDAL
vinothrajendran4 vinothrajendranbk at gmail.com
Fri Feb 10 05:46:53 PST 2017
Hi community,
            I have a geotiff data for a region. I would like to change the
corner coordinates manually... Is it posssible using GDAL , if so,  which
API is to be used......
      Is there any other method to accomplish it ???
Any help is appreciated...
Regards,
Vinoth R
View this message in context: http://osgeo-org.1560.x6.nabble.com/Can-i-modify-existing-coordinates-data-in-GeoTiff-using-GDAL-tp5307425.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
