[gdal-dev] Gdal Java - GetDefaultHistogram causing core dump
Vlad vladimir.sandoval at yandex.com
Fri Feb 10 06:32:34 PST 2017
Trying to get the histogram from a sample NITF.  Running from the command
line, gdalinfo -hist, I get this...
Band 1 Block=512x512 Type=Byte, ColorInterp=Undefined
0ERROR 1: COMRAT=4.50 ARIDPCM is not supported.
Currently only 0.75 is supported.
ERROR 1: U_0001A.NTF, band 1: IReadBlock failed at X offset 0, Y offset 0
In Java code (Gdal 2.1 from Maven against a Windows Gdal installation), this
line...
 int status = band.GetDefaultHistogram(dfMin, dfMax, panHistogram, true);
causes a dump...
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0000000078f7c1b0,
pid=2240, tid=3296
# JRE version: Java(TM) SE Runtime Environment (8.0_71-b15) (build
1.8.0_71-b15)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (25.71-b15 mixed mode
windows-amd64 compressed oops)
# Problematic frame:
# C  [msvcr100.dll+0x3c1b0]ERROR 1: COMRAT=4.50 ARIDPCM is not supported.
ERROR 1: B:\data\raster\NITF\U_0001A.NTF, band 1: IReadBlock failed at X
# Failed to write core dump. Minidumps are not enabled by default on client
versions of Windows
With exceptions enabled, I get the same thing without the ERROR string and
no exception is caught.
Culprit file is http://download.osgeo.org/gdal/data/nitf/nitf1.1/U_0001a.ntf
So, I can't check the status return from GetDefaultHistogram, I can't catch
an exception, and I think ARIDPCM is valid for NITF prior to 2.1, so I can't
really exclude ARIDPCM compression.
Workarounds or bug?
View this message in context: http://osgeo-org.1560.x6.nabble.com/Gdal-Java-GetDefaultHistogram-causing-core-dump-tp5307438.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
