[gdal-dev] How to remedy GDAL_DATA not found?
Even Rouault even.rouault at spatialys.com
Sun Feb 12 11:48:58 PST 2017
On jeudi 9 février 2017 15:55:45 CET sablok wrote:
> where we see that postgis is not able to find the gdal directory which has
> all the csv files it needs. So as a workaround I modified the gdal-config
> binary which has CONFIG_DATA variable to point to the directory where gdal
> is stored and restarted my postgres server after dropping the postgis
> extension completely. But I still get the same result.
> I don't want to add an environment variable per se, and looking for a way in
> which it can be done by just modifying any file that postgis is referring
> to while accessing gdal?
--> http://postgis.net/docs/postgis_gdal_datapath.html
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170212/7bc39606/attachment.html>
