[gdal-dev] "symbol(s) not found for architecture x86_64" when compiling GDAL 2.1.0 on Mac OS X
Even Rouault even.rouault at spatialys.com
Sun Feb 12 11:57:53 PST 2017
On dimanche 12 février 2017 11:46:39 CET Michal Migurski wrote:
> Thank you, Even!
> This should work for me currently, since I am using this installation of
> GDAL exclusively for vector work.
> If I wanted to compile a version that worked with JPEG and PNG support, am I
> currently out of luck?
No, this is the nominal setup. That should work. Only explicit --without-jpeg / --without-png is
rarely tested
> I do have the drivers via Homebrew and they have
> worked for me in the past.
If the external libraries are not found, the internal libraries are used (unless you explicity
disable them with --without-XXX)
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170212/2799ebc5/attachment.html>
