[gdal-dev] Placemark With Two Geometries Is Not Processed
Even Rouault even.rouault at spatialys.com
Wed Feb 15 09:22:24 PST 2017
On mercredi 15 février 2017 10:08:01 CET archgnulinux wrote:
> Even Rouault-2 wrote
> > From a quick try, I'd say that you must use the "old" KML driver. With the
> > LIBKML driver, the
> > reported geometry is the last one.
> Thanks, I am using the "old" KML driver.
> I tried to compile LIBKML for Windows awhile back but had quite a bit of
> trouble.
> I'll give it another try...
> Do you know of any distributions of GDAL with LIBKML?
You mention Windows, but your nickname is archgnulinux... So assuming the later, the GDAL
2.1.2 package in UbuntuGIS unstable for Xenial is built against libkml.
And I also see that the GDAL package in OSGEO4W has the libkml dependency.
> Philip
> http://osgeo-org.1560.x6.nabble.com/gdal-dev-Placemark-With-Two-Geometries-> Is-Not-Processed-tp5308067p5308076.html Sent from the GDAL - Dev mailing
> list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/gdal-dev
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170215/3523876e/attachment-0001.html>
