[gdal-dev] Fwd: Re: GDAL unable to write 4-band RGBA jp2 file with Kakadu 7.8
Aaron Boxer boxerab at gmail.com
Mon Feb 20 10:01:56 PST 2017
On Sat, Feb 18, 2017 at 8:14 AM, Kurt Schwehr <schwehr at gmail.com> wrote:
> Well,  I made a start as a part of gdal-autotest2...
> https://github.com/schwehr/gdal-autotest2/blob/master/
> cpp/third_party/kakadu/coresys/common/kdu_arch_test.cc
That is a good start.
> On Sat, Feb 18, 2017 at 5:03 AM, Aaron Boxer <boxerab at gmail.com> wrote:
>> ---------- Forwarded message ----------
>> From: "Aaron Boxer" <boxerab at gmail.com>
>> Date: Feb 18, 2017 8:03 AM
>> Subject: Re: [gdal-dev] GDAL unable to write 4-band RGBA jp2 file with
>> Kakadu 7.8
>> To: "Kurt Schwehr" <schwehr at gmail.com>
>> Cc:
>> On Feb 18, 2017 7:26 AM, "Kurt Schwehr" <schwehr at gmail.com> wrote:
>> Jason,
>> Turns out you are hitting a known bug in v7.8 that is fixed in v7.9.
>> From the kakadu v7.9 docs:
>> h. Corrected a tiny, yet very significant bug introduced into the
>>    handling of opacity channel descriptions in version 7.8.  The
>>    correction is in function `jp2_channels::set_opacity_mapping', where
>>    the opacity channel's component index accidentally overwrote the
>>    colour channel's component index.
>> Apparently Kakadu does no regression testing before a release 😁
>> It's pretty easy to backport the fix if you are currently stuck at 7.8.
>> It's just a change of a 0 to a 1.
>> --- kakadu/v7_8/apps/jp2/jp2.cpp
>> +++ kakadu/v7_9/apps/jp2/jp2.cpp
>> @@ -5976,7 +5976,7 @@
>>    if (lut_idx < 0)
>>      lut_idx = -1; // For consistency in comparisons later on.
>>    j2_channels::j2_channel *cp = state->channels+colour_idx;
>> -  cp->component_idx[0] = codestream_component;
>> +  cp->component_idx[1] = codestream_component; /* Was a bug in version
>> 7.8 */
>>    cp->lut_idx[1] = lut_idx;
>>    cp->codestream_idx[1] = codestream_idx;
>>    cp->data_format[1] = data_format;
>> The 0 can trigger an error that looks just like you are seeing:
>> Error: GdalIO: Error in Kakadu File Format Support: Attempting to create
>> a Component Mapping (cmap) box, one of whose channels refers to a
>> non-existent image component or palette lookup table. (code = 1)
>> On Mon, Feb 13, 2017 at 9:28 PM, Kurt Schwehr <schwehr at gmail.com> wrote:
>>> Hi Jason,
>>> I've seen the same thing with an alpha channel.  I'm not sure what's
>>> up.  Using just RGB was successful.
>>> On 7.3, I'm also seeing problems when using more than the main thread on
>>> linux.
>>> With 7.3, I just noticed today that kdu_get_num_processors() only
>>> returns 0 on linux as kdu_arch.cpp is missing #include <unistd.h> so
>>> _SC_NPROCESSORS_ONLN and _SC_NPROCESSORS_CONF are undefined.  When I
>>> enabled _SC_NPROCESSORS_ONLN, I got kdu_get_num_processors() returning 74
>>> on what I thought was a 6 core (aka 12 hyperthread) box.   If I change the
>>> fall through from 0 to 2, I get all sorts of trouble from internal kakadu
>>> assertions and TSAN failures.
>>> So I clearly have more investigating to do.
>>> I've yet to pass along any of what I've found to Taubman and I haven't
>>> yet pushed any of my new tests to github, but I hope to do both soon.
>>> And I've yet to see what, if any, discussion is happening in the yahoo
>>> group.
>>> -kurt
>>> On Mon, Feb 13, 2017 at 8:14 PM, jason.liu <jason.liu at spookfish.com>
>>> wrote:
>>>> Hi gdal-dev,
>>>> I am having trouble using GDAL to write 4-band RGBA jp2 file with Kakadu
>>>> 7.8. The following minimal code
>>>>     GDALAllRegister();
>>>>     GDALDataset* srcDataset =
>>>> (GDALDataset*)GDALOpen("/home/jason.liu/00000783.tif", GA_ReadOnly);
>>>>     char **papszOptions = NULL;
>>>>     papszOptions = CSLSetNameValue( papszOptions, "QUALITY", "20" );
>>>>     GDALDriver *driver = GetGDALDriverManager()->GetDri
>>>> verByName("JP2KAK");
>>>>     GDALDataset* destDataset =
>>>> driver->CreateCopy("/home/jason.liu/00000783.jp2",
>>>>                                                   srcDataset,
>>>>                                                   FALSE,
>>>>                                                   papszOptions,
>>>>                                                   NULL,
>>>>                                                   NULL);
>>>>     if( destDataset != NULL ) {
>>>>         GDALClose( (GDALDatasetH) destDataset );
>>>>     GDALClose( (GDALDatasetH) srcDataset );
>>>>     CSLDestroy(papszOptions);
>>>> crashes Kakadu 7.8 with the following message in stderr:
>>>> ERROR 1: Error in Kakadu File Format Support:
>>>> Attempting to create a Component Mapping (cmap) box, one of whose
>>>> channels
>>>> refers to a non-existent image component or palette lookup table.
>>>> terminate called after throwing an instance of
>>>> 'kdu_cpl_error_message::JP2KAKException'
>>>> where /home/jason.liu/00000783.tif is a 4-band 16-bit RGBA tif.
>>>> I have also done the following tests and noted the results:
>>>> 3-band 8-bit RGB tif            OK
>>>> 3-band 16-bit RGB tif          OK
>>>> 4-band 8-bit RGBA tif          error as above
>>>> 4-band 16-bit RGBA tif        error as above
>>>> Am I doing anything wrong here?
>>>> By the way, I am quite certain Kakadu 7.8 supports 4-band RGBA as I can
>>>> use
>>>> their example kdu_compress to produce 4-band RGBA jp2 images. So this
>>>> looks
>>>> to be a problem with GDAL, or the way I am invoking it.
>>>> Any insights will be greatly appreciated.
>>>> Kind Regards
>>>> Jason
>>>> View this message in context: http://osgeo-org.1560.x6.nabbl
>>>> e.com/GDAL-unable-to-write-4-band-RGBA-jp2-file-with-Kakadu-
>>>> 7-8-tp5307801.html
>>>> Sent from the GDAL - Dev mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> gdal-dev mailing list
>>>> gdal-dev at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/gdal-dev
>>> http://schwehr.org
>> http://schwehr.org
> http://schwehr.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170220/70a8152c/attachment-0001.html>
