[gdal-dev] [feature request] add smoothing parameter to gdal_grid invdistnn algorithm?
stellasia stell4sia at gmail.com
Wed Feb 22 01:18:23 PST 2017
Hello,
I am a new gdal user (less than one month), trying to generate a raster
with gdal_grid utility.
I was wondering why there isn't a smoothing parameter with the invdistnn
algorithm in gdal_grid?
I am facing a problem where I would like to have both the nearest
neighbours (to limit radius of influence) and the smoothing in the average
computation, but maybe I misunderstood the purpose.
If you think that adding a smoothing in this case is relevant, I can submit
a PR with a patch suggestion.
Best,
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170222/c995e6f7/attachment.html>
