[gdal-dev] Usage of GDAL_FILENAME_IS_UTF8 config option
Damian Dixon damian.dixon at gmail.com
Mon Jan 9 02:03:58 PST 2017
Hi Victor,
If you set GDAL_FILENAME_IS_UTF8 to YES then you need to pass in filenames
and paths encoded as UTF8.
This means that on Windows you will need to do additional work to convert
from MBCS or UTF16/UCS2 to UTF8.
If your application is built as MBCS then what you essentially have is a
multi-byte string encoding which is the Windows local code page.
If your application is built for Unicode then you have UTF16/UCS2 so you
have to convert the filenames to UTF8 for GDAL/OGR to work.
If you save the filenames as part of an application specific configuration
then you need to consider how you will read read that data back in if the
Windows code page changes. This is not an easy task unless you also save
the code page as well. It also becomes a bit of a mess supporting this on
non-Windows.
The approach we took was to convert our Windows applications to Unicode and
store/use all paths/filenames as UTF8 for portability to
Linux/Android/Solaris.
Regards
Damian
PS. Microsoft has deprecated MBCS build of MFC.
On 9 January 2017 at 09:31, Poughon Victor <Victor.Poughon at cnes.fr> wrote:
> Hi,
> We are using GDAL in OTB and recently we had a bug report about opening non
> ASCII filenames on Windows 10 [0]. They suggest a fix using:
> > CPLSetConfigOption("GDAL_FILENAME_IS_UTF8","NO");
> The test case is GDALOpen() on a file named 你好.tif, which I confirmed works
> fine on Linux, but not on Windows 7 or 10.
> So my question is to have some clarification on this option, to know if
> it's
> potentially the correct fix for this problem. The doc says:
> > This effectively restores the pre-GDAL1.8 behavior for handling
> filenames on
> > Windows and might be appropriate for applications that treat filenames as
> > being in the local encoding.
> What does it mean exactly to consider filenames to be in the local
> encoding? And
> how do I know if my application [1] does that?
> Cheers,
> [0] https://github.com/orfeotoolbox/OTB/pull/14
> [1] https://github.com/janestar/OTB/blob/f6ffdc17ab3d7aa91726f03ed619fe
> e806eb508a/Modules/IO/IOGDAL/src/otbGDALDriverManagerWrapper.cxx#L55
> Victor Poughon
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170109/5b9c79eb/attachment.html>
