[gdal-dev] Anyone interested in resurrecting PHP (7) bindings ?
Even Rouault even.rouault at spatialys.com
Tue Jan 10 06:15:05 PST 2017
Seeing https://trac.osgeo.org/gdal/ticket/6770, I realized that we have in-tree
PHP bindings...
They appear to still build with PHP 5 on an ancient distro, but they are broken
with PHP 7.
I've tried the attached patch that attempts to use the -php7 flag available in SWIG
3.0.11 but this still results in build failures (see attached log).
Failing to find anyone interested, we'll have to disable
./configure --with-php
Even
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170110/fb944fed/attachment-0001.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170110/fb944fed/attachment-0001.bin>
gdal_wrap.cpp:4652:63: error: macro "add_assoc_string" passed 4 arguments, but takes just 3
           add_assoc_string(return_value,keyptr,(char*)valptr,1);
gdal_wrap.cpp: In function ‘zval* CreateTupleFromDoubleArray(double*, unsigned int)’:
gdal_wrap.cpp:1403:22: error: ‘MAKE_STD_ZVAL’ was not declared in this scope
     MAKE_STD_ZVAL(tmp);
gdal_wrap.cpp: In function ‘char* OGRErrMessages(int)’:
gdal_wrap.cpp:1651:12: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
     return "OGR Error 0: None";
gdal_wrap.cpp:1653:12: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
     return "OGR Error 1: Not enough data";
gdal_wrap.cpp:1655:12: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
     return "OGR Error 2: Unsupported geometry type";
gdal_wrap.cpp:1657:12: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
     return "OGR Error 3: Unsupported operation";
gdal_wrap.cpp:1659:12: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
     return "OGR Error 4: Corrupt data";
gdal_wrap.cpp:1661:12: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
     return "OGR Error 5: General Error";
gdal_wrap.cpp:1663:12: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
     return "OGR Error 6: Unsupported SRS";
gdal_wrap.cpp:1665:12: warning: deprecated conversion from string constant to ‘char*’ [-Wwrite-strings]
     return "OGR Error: Unknown";
gdal_wrap.cpp: In function ‘CPLErr GDALRasterBandShadow_GetHistogram(GDALRasterBandShadow*, double, double, int, int*, int, int, GDALProgressFunc, void*)’:
gdal_wrap.cpp:1868:18: warning: ‘CPLErr GDALGetRasterHistogram(GDALRasterBandH, double, double, int, int*, int, int, GDALProgressFunc, void*)’ is deprecated [-Wdeprecated-declarations]
     CPLErr err = GDALGetRasterHistogram( self, min, max, buckets, panHistogram,
In file included from gdal_wrap.cpp:1134:0:
../../gcore/gdal.h:793:28: note: declared here
 CPLErr CPL_DLL CPL_STDCALL GDALGetRasterHistogram( GDALRasterBandH hBand,
gdal_wrap.cpp:1870:66: warning: ‘CPLErr GDALGetRasterHistogram(GDALRasterBandH, double, double, int, int*, int, int, GDALProgressFunc, void*)’ is deprecated [-Wdeprecated-declarations]
                                          callback, callback_data );
gdal_wrap.cpp: In function ‘CPLErr GDALRasterBandShadow_GetDefaultHistogram(GDALRasterBandShadow*, double*, double*, int*, int**, int, GDALProgressFunc, void*)’:
gdal_wrap.cpp:1874:12: warning: ‘CPLErr GDALGetDefaultHistogram(GDALRasterBandH, double*, double*, int*, int**, int, GDALProgressFunc, void*)’ is deprecated [-Wdeprecated-declarations]
     return GDALGetDefaultHistogram( self, min_ret, max_ret, buckets_ret,
../../gcore/gdal.h:805:28: note: declared here
 CPLErr CPL_DLL CPL_STDCALL GDALGetDefaultHistogram( GDALRasterBandH hBand,
gdal_wrap.cpp:1876:61: warning: ‘CPLErr GDALGetDefaultHistogram(GDALRasterBandH, double*, double*, int*, int**, int, GDALProgressFunc, void*)’ is deprecated [-Wdeprecated-declarations]
gdal_wrap.cpp: In function ‘CPLErr GDALRasterBandShadow_SetDefaultHistogram(GDALRasterBandShadow*, double, double, int, int*)’:
gdal_wrap.cpp:1879:12: warning: ‘CPLErr GDALSetDefaultHistogram(GDALRasterBandH, double, double, int, int*)’ is deprecated [-Wdeprecated-declarations]
     return GDALSetDefaultHistogram( self, min, max,
../../gcore/gdal.h:817:28: note: declared here
 CPLErr CPL_DLL CPL_STDCALL GDALSetDefaultHistogram( GDALRasterBandH hBand,
gdal_wrap.cpp:1880:44: warning: ‘CPLErr GDALSetDefaultHistogram(GDALRasterBandH, double, double, int, int*)’ is deprecated [-Wdeprecated-declarations]
                buckets_in, panHistogram_in );
In file included from /usr/include/php/20151012/Zend/zend.h:31:0,
                 from gdal_wrap.cpp:748:
gdal_wrap.cpp: In function ‘void _wrap_EscapeString(zend_execute_data*, zval*)’:
/usr/include/php/20151012/Zend/zend_types.h:337:35: error: no match for ‘operator*’ (operand type is ‘zval {aka _zval_struct}’)
 #define Z_TYPE_P(zval_p)   Z_TYPE(*(zval_p))
/usr/include/php/20151012/Zend/zend_types.h:336:41: note: in definition of macro ‘Z_TYPE’
 #define Z_TYPE(zval)    zval_get_type(&(zval))
/usr/include/php/20151012/Zend/zend_operators.h:368:6: note: in expansion of macro ‘Z_TYPE_P’
  if (Z_TYPE_P(pzv)!=upper_type) {     \
/usr/include/php/20151012/Zend/zend_operators.h:410:35: note: in expansion of macro ‘convert_to_ex_master’
 #define convert_to_string_ex(pzv) convert_to_ex_master(pzv, string, IS_STRING)
gdal_wrap.cpp:3435:5: note: in expansion of macro ‘convert_to_string_ex’
     convert_to_string_ex(args[0]);
/usr/include/php/20151012/Zend/zend_operators.h:274:35: note: in expansion of macro ‘Z_TYPE_P’
 #define convert_to_string(op) if (Z_TYPE_P(op) != IS_STRING) { _convert_to_string((op) ZEND_FILE_LINE_CC); }
/usr/include/php/20151012/Zend/zend_operators.h:369:3: note: in expansion of macro ‘convert_to_string’
   convert_to_##lower_type(pzv);      \
In file included from /usr/include/php/20151012/Zend/zend.h:341:0,
/usr/include/php/20151012/Zend/zend_operators.h:274:105: error: cannot convert ‘zval {aka _zval_struct}’ to ‘zval* {aka _zval_struct*}’ for argument ‘1’ to ‘void _convert_to_string(zval*)’
gdal_wrap.cpp:3436:31: error: ‘Z_STRVAL_PP’ was not declared in this scope
     arg2 = Z_STRVAL_PP(args[0]);
gdal_wrap.cpp:3437:31: error: ‘Z_STRLEN_PP’ was not declared in this scope
     arg1 = Z_STRLEN_PP(args[0]);
gdal_wrap.cpp: In function ‘void _wrap_MajorObject_GetMetadata_Dict(zend_execute_data*, zval*)’:
gdal_wrap.cpp:4652:11: error: ‘add_assoc_string’ was not declared in this scope
gdal_wrap.cpp: In function ‘void _wrap_MajorObject_GetMetadata_List(zend_execute_data*, zval*)’:
gdal_wrap.cpp:4707:62: error: too many arguments to function ‘int add_next_index_string(zval*, const char*)’
         add_next_index_string( return_value, *stringarray, 1 );
In file included from gdal_wrap.cpp:749:0:
/usr/include/php/20151012/Zend/zend_API.h:432:14: note: declared here
 ZEND_API int add_next_index_string(zval *arg, const char *str);
gdal_wrap.cpp: In function ‘void _wrap_GCPsToGeoTransform(zend_execute_data*, zval*)’:
gdal_wrap.cpp:6850:39: error: cannot convert ‘zval** {aka _zval_struct**}’ to ‘zval* {aka _zval_struct*}’ for argument ‘1’ to ‘void t_output_helper(zval*, zval*)’
     t_output_helper( &return_value, t );
gdal_wrap.cpp: In function ‘void _wrap_Dataset_GetGeoTransform(zend_execute_data*, zval*)’:
gdal_wrap.cpp:7309:39: error: cannot convert ‘zval** {aka _zval_struct**}’ to ‘zval* {aka _zval_struct*}’ for argument ‘1’ to ‘void t_output_helper(zval*, zval*)’
gdal_wrap.cpp: In function ‘void _wrap_Dataset_GetGCPs(zend_execute_data*, zval*)’:
gdal_wrap.cpp:7535:22: error: ‘MAKE_STD_ZVAL’ was not declared in this scope
     MAKE_STD_ZVAL(out);
gdal_wrap.cpp: In function ‘void _wrap_Band_GetRasterCategoryNames(zend_execute_data*, zval*)’:
gdal_wrap.cpp:8364:62: error: too many arguments to function ‘int add_next_index_string(zval*, const char*)’
gdal_wrap.cpp: In function ‘void _wrap_Band_Checksum(zend_execute_data*, zval*)’:
gdal_wrap.cpp:8965:25: error: no match for ‘operator*’ (operand type is ‘zval {aka _zval_struct}’)
       if ( ZVAL_IS_NULL(*args[3]) ) {
/usr/include/php/20151012/Zend/zend_API.h:647:26: note: in expansion of macro ‘Z_TYPE_P’
 #define ZVAL_IS_NULL(z) (Z_TYPE_P(z) == IS_NULL)
gdal_wrap.cpp:8965:12: note: in expansion of macro ‘ZVAL_IS_NULL’
/usr/include/php/20151012/Zend/zend_operators.h:408:34: note: in expansion of macro ‘convert_to_ex_master’
 #define convert_to_long_ex(pzv)  convert_to_ex_master(pzv, long, IS_LONG)
gdal_wrap.cpp:8968:7: note: in expansion of macro ‘convert_to_long_ex’
       convert_to_long_ex(args[3]);
/usr/include/php/20151012/Zend/zend_operators.h:369:30: error: cannot convert ‘zval {aka _zval_struct}’ to ‘zval* {aka _zval_struct*}’ for argument ‘1’ to ‘void convert_to_long(zval*)’
gdal_wrap.cpp:8969:39: error: ‘Z_LVAL_PP’ was not declared in this scope
       val4 = (int) Z_LVAL_PP( args[3] );
gdal_wrap.cpp:8976:25: error: no match for ‘operator*’ (operand type is ‘zval {aka _zval_struct}’)
       if ( ZVAL_IS_NULL(*args[4]) ) {
gdal_wrap.cpp:8976:12: note: in expansion of macro ‘ZVAL_IS_NULL’
gdal_wrap.cpp:8979:7: note: in expansion of macro ‘convert_to_long_ex’
       convert_to_long_ex(args[4]);
gdal_wrap.cpp:8980:39: error: ‘Z_LVAL_PP’ was not declared in this scope
       val5 = (int) Z_LVAL_PP( args[4] );
gdal_wrap.cpp: In function ‘void _wrap_Band_ComputeRasterMinMax(zend_execute_data*, zval*)’:
gdal_wrap.cpp:9030:39: error: cannot convert ‘zval** {aka _zval_struct**}’ to ‘zval* {aka _zval_struct*}’ for argument ‘1’ to ‘void t_output_helper(zval*, zval*)’
gdal_wrap.cpp: In function ‘void _wrap_Band_ComputeBandStats(zend_execute_data*, zval*)’:
gdal_wrap.cpp:9074:39: error: cannot convert ‘zval** {aka _zval_struct**}’ to ‘zval* {aka _zval_struct*}’ for argument ‘1’ to ‘void t_output_helper(zval*, zval*)’
gdal_wrap.cpp: In function ‘void _wrap_Band_GetCategoryNames(zend_execute_data*, zval*)’:
gdal_wrap.cpp:9694:62: error: too many arguments to function ‘int add_next_index_string(zval*, const char*)’
gdal_wrap.cpp: In function ‘void _wrap_RasterAttributeTable_SetValueAsString(zend_execute_data*, zval*)’:
gdal_wrap.cpp:10464:5: note: in expansion of macro ‘convert_to_string_ex’
     convert_to_string_ex(args[3]);
gdal_wrap.cpp:10465:33: error: ‘Z_STRVAL_PP’ was not declared in this scope
     arg4 = Z_STRVAL_PP( args[3] );
gdal_wrap.cpp: In function ‘void _wrap_Transformer_TransformPoint__SWIG_0(zend_execute_data*, zval*)’:
gdal_wrap.cpp:12312:39: error: cannot convert ‘zval** {aka _zval_struct**}’ to ‘zval* {aka _zval_struct*}’ for argument ‘1’ to ‘void t_output_helper(zval*, zval*)’
gdal_wrap.cpp: In function ‘void _wrap_Transformer_TransformPoint__SWIG_1(zend_execute_data*, zval*)’:
gdal_wrap.cpp:12377:39: error: cannot convert ‘zval** {aka _zval_struct**}’ to ‘zval* {aka _zval_struct*}’ for argument ‘1’ to ‘void t_output_helper(zval*, zval*)’
gdal_wrap.cpp: In function ‘void _wrap_InvGeoTransform(zend_execute_data*, zval*)’:
gdal_wrap.cpp:12699:39: error: cannot convert ‘zval** {aka _zval_struct**}’ to ‘zval* {aka _zval_struct*}’ for argument ‘1’ to ‘void t_output_helper(zval*, zval*)’
gdal_wrap.cpp: In function ‘void _wrap_GeneralCmdLineProcessor(zend_execute_data*, zval*)’:
gdal_wrap.cpp:13729:62: error: too many arguments to function ‘int add_next_index_string(zval*, const char*)’
make: *** [gdal_wrap.o] Erreur 1
