[gdal-dev] C++11 timeline
Andrew Bell andrew.bell.ia at gmail.com
Thu Jan 12 15:10:39 PST 2017
There's a lot of code to work on.  Would it make sense just to make a C++11
branch and get to work, merging into master whenever it seems the right
time?
On Thu, Jan 12, 2017 at 2:42 PM, Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On 13 January 2017 at 02:57, Greg Troxel <gdt at lexort.com> wrote:
> > Kurt Schwehr <schwehr at gmail.com> writes:
> > If no other packages start to depend on unreleased GDAL, and the first
> > GDAL release requiring C++11 is a ways off, and by then enough other
> > things require it that a system not having a C++11 compiler is totally
> > non-viable, then this shouldn't cause problems for pkgsrc.
> FYI - the upcoming QGIS 3.0 release has a hard c++11 requirement. Not
> sure how much that affects things, but certainly projects which
> utilise GDAL are already switching to c++11.
> Nyall
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Andrew Bell
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170112/0ccbb0ba/attachment.html>
