[gdal-dev] C++11 timeline
Jürgen E. Fischer jef at norbit.de
Sat Jan 14 01:13:48 PST 2017
Hi Greg,
On Fri, 13. Jan 2017 at 19:15:27 -0500, Greg Troxel wrote:
> > We're not using the C++ API - so that shouldn't matter.
> I took the comment to mean that since QGIS would require c++11, if you
> wanted to run QGIS, you'd ned to cope with a new-enough compiler, in
> which case GDAL also needing it would not be an incremental burden.
Well, it just meant that we use the C API and therefore are not tied to use the
same compiler for GDAL and QGIS.
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-31
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
Name: not available
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170114/0730a729/attachment.sig>
