[gdal-dev] PostGIS with more than one geometry column per table | R-Trees
Alexander Berdnikow alexander.berdnikow at mettenmeier.de
Mon Jan 16 06:24:05 PST 2017
Thank you, Even!
Even Rouault-2 wrote
> On vendredi 13 janvier 2017 16:54:55 CET
> Alexander.Berdnikow@
>  wrote:
>> I've read about the solution of the multiple geometries issue in
>> GeoPackage in the GP-specification. Does GDAL support this in the
>> translation process (maybe with a special option?)?
> Not sure which solution you are talking about.
http://www.geopackage.org/modeling_guidelines.html
Use Case 2 describes a way how to handle multiple geometries in GeoPackage.
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-PostGIS-with-more-than-one-geometry-column-per-table-R-Trees-tp5303398p5303622.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
