[gdal-dev] Question about .aux.xml sidecar file handling...
jratike80 jukka.rahkonen at maanmittauslaitos.fi
Wed Jan 18 14:00:12 PST 2017
Carl Godkin-2 wrote
> Hi,
> I have a geological map in a pair of files called USGS.tif and
> USGS.tif.aux.xml
> The XML seems to have ground control points (
> <SourceGCPs>
> ) and a geographic
> coordinate system (
> <SpatialReference>
> I was hoping that GDAL would treat the file as if it's a GeoTIFF.  But if
> I
> run gdalinfo on the .tif, it doesn't seem to read the coordinate system or
> GCPs.  Instead, I see this:
> Driver: GTiff/GeoTIFF
> Files: USGS.tif
>        USGS.tif.aux.xml
> Size is 11451, 12188
> Coordinate System is `'
> Corner Coordinates:
> Upper Left  (    0.0,    0.0)
> Lower Left  (    0.0,12188.0)
> Upper Right (11451.0,    0.0)
> Lower Right (11451.0,12188.0)
> Center      ( 5725.5, 6094.0)
> Am I missing something?  I have GDAL_DATA set appropriately and am using
> GDAL 2.1.1 on Windows.
> I would like to either treat the .tif + .tif.aux.xml as a GeoTIFF or else
> translate it to one.
> Thanks very much,
> carl
Image is georeferenced with ground control points. I wonder what happens if
you push it through gdalwarp:
gdalwarp -s_srs epsg:xxxx -t_srs epsg:xxxx USGS.tif USGS_warped.tif
-Jukka Rahkonen-
View this message in context: http://osgeo-org.1560.x6.nabble.com/gdal-dev-Question-about-aux-xml-sidecar-file-handling-tp5303876p5303953.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
