[gdal-dev] Shapefile with one feature and many incrementally-added vertices is huge
Michael Sumner mdsumner at gmail.com
Thu Jan 19 19:50:13 PST 2017
A long shot but does any of this help re Mac?
https://github.com/edzer/sfr/issues/40
On Fri, Jan 20, 2017, 10:46 Nik Sands <nik at nixanz.com> wrote:
> Thanks Guys,
> I appreciate the great responses, and particularly implementing an update
> for this edge case.
> Unfortunately, I'm stuck with GDAL 1.x for now (have yet to figure out how
> to get 2.x to build for iOS, but will take another look some time).
> As for alternatives to Shapefiles, my preference is for SQLite/Spatialite,
> but I'm having other problems with that at present (haven't defined the
> problems well enough to post a query here yet).
> I will take a look at GeoPackage.  I'm not familiar with this format.
> Cheers,
> Nik.
> ----- Original Message -----
> From:
> "Stefan Keller" <sfkeller at gmail.com>
> To:
> "Even Rouault" <even.rouault at spatialys.com>
> Cc:
> "gdal-dev at lists.osgeo.org" <gdal-dev at lists.osgeo.org>
> Sent:
> Thu, 19 Jan 2017 15:31:07 +0100
> Subject:
> Re: [gdal-dev] Shapefile with one feature and many incrementally-added
> vertices is huge
> @Even: Great work!
> @Nik: I would avoid using Shapefile in the first place.
> IMHO there are other formats which hare better suited for this use
> case, like e.g. GeoPackage.
> :Stefan
> 2017-01-19 14:38 GMT+01:00 Even Rouault <even.rouault at spatialys.com>:
> >> In that
> >> particular case the writer could realize that we are editing the last
> >> geometry, so it could safely overwrite in place, but this isn't
> >> implemented
> >> yet.
> > Well, that was rather simple to implement. So fixed per
> > https://trac.osgeo.org/gdal/ticket/6787
> > Even
> > Spatialys - Geospatial professional services
> > http://www.spatialys.com
> > gdal-dev mailing list
> > https://lists.osgeo.org/mailman/listinfo/gdal-dev
Dr. Michael Sumner
Software and Database Engineer
Australian Antarctic Division
203 Channel Highway
Kingston Tasmania 7050 Australia
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20170120/429cf30c/attachment.html>
